OSPF on X440 Edge Core
Edgar_Dattoli
Hi.
Can I make work OSPF in a X440 network?
I have 3 X440, two on remote locations, and one in HQ. I have configured the OSPF by this way:
Switch "80":
configure ospf routerid 0.0.0.80
create ospf area 0.0.0.1
configure ospf add vlan VLAN_A area 0.0.0.1
configure ospf add vlan VLAN_B area 0.0.0.1
enable ospf
Switch "81":
configure ospf routerid 0.0.0.81
configure ospf add vlan VLAN_C area 0.0.0.1
enable ospf
Switch "82":
configure ospf routerid 0.0.0.82
enable ospf
And if I check the ospf in the interfaces:
SWITCH80.25 # show ospf interfaces VLAN IP Address AREA ID Flags Cost State Neighbors
VLAN_A 10.0.1.1 /24 0.0.0.1 -rif--- 4/A ODR 1
VLAN_B 10.0.2.1 /24 0.0.0.1 -rif--- 4/A ODR 1
And the same in the switches 81, and 82.
What is the ODR? Why are not working the OSPF?
Bests
2 REPLIES 2
Stephane_Grosj1
Or use p2p type link.
Bill_Stritzinge
Edgar,
You can use the X440 for edge OSPF but since they cannot be used with a core license they can never be a DR. Thus with no DR there is not a designated OSPF router to hold the database. You have to have another device that holds a core license (in Extreme world) or another router that can act as a DR. Let me know if you have a question!
Bill
