OSPF configuration on Enterasys S series - default routes and passive interfaces.
  • Question
  • Updated 4 years ago
  • Answered
I have 2 questions about OSPF configuration:
Firstly - Is there an equivalent to the Cisco command default-information originate ?
If not, how should I go about advertising a default route in a single area OSPF network.
Secondly - I see the passive-interface command, but is there an equivalent to the passive-interface default
command? I have quite a lot of routed interfaces that I want included in OSPF as passive interfaces, but I'd rather not have to go through and specify each and every one as passive. It would be much easier to set passive-interface default and then negate the command for those interfaces connected to other routers.
Photo of Jon P
Jon P
  • 160 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Michael Dubay
Michael Dubay
  • 90 Points 75 badge 2x thumb
re: default route advert -
*current support:  Static definition and then redistribute
*in test (no date) default originate command
re: passive-int default
* current support
Photo of Jon P
Jon P
So you're saying that I'd use the redistribute static command to advertise the default route?
Regarding passive-int default - are you saying this command is available? I have been unable to find it either on the devices or in the CLI guides. Has it been introduced in a recent firmware?
Michael Dubay
re: redistribute static - yes.  This is currently how the default route is injected into single area/area 0
passive interface default
yes, fairly new support.  This has been supported since (i believe) 8.11 code release.
Michael Dubay
Hello Jon P,
regarding passive-interface default in S-series documentation:
We are correcting this in our documentation - and thank you for pointing out the oversight.
Best,
Mike d
Photo of Jon P
Jon P
Thanks. If we're running earlier firmware which does not support the passive interface default command, is it possible to use something like
passive interface vlan.*.*
to apply the command to all interfaces?
Michael Dubay
No such command or nor similar available in older revs Jon.
Mike d
