OSPF redistribute static (blackhole) routes
  • Question
  • Updated 5 years ago
Hi everybody.
I have Summit x480 with connected subnet 172.30.0.0/16. But I'd like to advertise to OSPF process another subnets like 172.30.20.0/24, 172.30.21.0/24 and so forth.
I try to create routes via Null0 and export these to OSPF, but I find only "blackhole" routes.
Can I export blackhole routes to OSPF? Can anybody suggest me another way to advertise /24 subnets.
Photo of eyeV
eyeV
  • 2,484 Points 2k badge 2x thumb
Posted 5 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Create the loopback interface.
Assign the IP address to the loopback interface.
Advertise the loopback vlan into OSPF.
Photo of eyeV
eyeV
Thank you, but...
I have Vlan Default with IP address 172.30.0.254/16 and I can't assign IP address 172.30.20.1/24 to my loopback VLAN. It's overlaps.
I only want to advertise /24 subnets.
Sumit Tokle, Alum
May I know why you wants to do this?
Photo of eyeV
eyeV
Sure, I try to explain. I hope you will understand me, because my English isn't good actually.
We have one VLAN trough all our network. It's vlan Default with 172.30.0.0/16 subnet. We've decided to split this VLAN and add some L3 routing between part of it. We don't want to change IP addressing scheme in these part, because there are a lot of devices in it.
It's a bit difficult to explain this. Now I think we should change our IP addressing scheme.
Sorry for my English.
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
Take the setup below:[attached]
Simple setup with all in 0.0.0.0
SW1:
# Module vlan configuration.
create vlan black-hole
configure vlan black-hole ipaddress 15.1.1.1 255.255.255.0
enable ipf black-hole
enable loopback-mode vlan black-hole
create vlan sw1-sw2
configure vlan sw1-sw2 ipaddress 30.30.30.2 255.255.255.252
enable ipf sw1-sw2
configure vlan sw1-sw2 tag 500
configure vlan sw1-sw2 add ports 14 tagged
# Module ospf configuration.
enable ospf
configure ospf add vlan sw1-sw2 area 0.0.0.0
SW2:
create vlan sw2-sw1 tag 500
configure vlan sw2-sw1 ipaddress 30.30.30.1 255.255.255.252
enable ipf sw2-sw1
configure vlan sw2-sw1 add ports 14 tagged
create vlan sw2-sw3 tag 20
configure vlan sw2-sw3 ipaddress 20.20.20.1 255.255.255.252
enable ipf sw2-sw3
configure vlan sw2-sw3 add ports 15 tagged
enable ospf
configure ospf add vlan sw2-sw1 area 0.0.0.0
configure ospf add vlan sw2-sw3 area 0.0.0.0
SW3:
create vlan sw3-sw2 tag 20
configure vlan sw3-sw2 ipaddress 20.20.20.2 255.255.255.252
enable ipf sw3-sw2
configure vlan sw3-sw2 add ports 15 tagged
enable ospf
configure ospf add vlan sw3-sw2 area 0.0.0.0
Now to create the so called black-hole routes, on switch1:
SW1:
create fdbentry 00:00:06:00:00:01 vlan "black-hole" blackhole
configure iparp add 15.1.1.2 vr VR-Default 00:00:06:00:00:01
configure iproute add 170.1.0.0/24 15.1.1.2
configure iproute add 170.2.0.0/24 15.1.1.2
configure iproute add 170.3.0.0/24 15.1.1.2
configure iproute add 170.4.0.0/24 15.1.1.2
configure iproute add 170.5.0.0/24 15.1.1.2
configure iproute add 170.6.0.0/24 15.1.1.2
configure iproute add 170.7.0.0/24 15.1.1.2
configure iproute add 170.8.0.0/24 15.1.1.2
configure iproute add 170.9.0.0/24 15.1.1.2
configure iproute add 170.10.0.0/24 15.1.1.2
enable ospf export static cost 10 type ase-type-2
SW3:
npi_670-2.14 # sh ipr
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#o2  170.1.0.0/24       20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
#o2  170.2.0.0/24       20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
#o2  170.3.0.0/24       20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
#o2  170.4.0.0/24       20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
#o2  170.5.0.0/24       20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
#o2  170.6.0.0/24       20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
#o2  170.7.0.0/24       20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
#o2  170.8.0.0/24       20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
#o2  170.9.0.0/24       20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
#o2  170.10.0.0/24      20.20.20.1      10   UG-D---um--f- ospf-test  0d:0h:0m:22s
Now obviously these will not be installed as blackhole routes but it is providing a way to send traffic destined to those subnets nowhere.
Photo of eyeV
eyeV
It seems a bit strange. Thank you for answer.
