OSPF Troubleshooting quesitons..
  • Question
  • Updated 4 years ago
  • (Edited)
The problem right now is that our outbound traffic is only using one of our many MPLS pipes. And i reckon this is because there is only one advertising router for those networks.
1. We have multiple ISP routers redistributing routes (they say they do) into our OSPF network. But on our internal routers i only see one entry in the LSDB. Is this normal ..or is our ISP lying
2. The VLANs added to EAPS are also the ones with interfaces on OSPF.. so would EAPS be preventing OSPF LSAs ?
Photo of yuvi
yuvi
  • 122 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
You should see one routes in the routing table but multiple in LSDB. EAPS should not prevent OSPF LSA untill and unless the port is in active for the EAPS domain.
Photo of yuvi
yuvi
Simit,
Thanks for the reply, can you clarify on the point you made " EAPS should not prevent OSPF LSA untill and unless the port is in active for the EAPS domain."...
port is "in active" ? as in ?
Photo of andreas
andreas
  • 1,218 Points 1k badge 2x thumb
EAPS will not block any LSAs. Can you post a snippet of your OSPF config maybe ?
Photo of yuvi
yuvi
show configuration ospf#
# Module ospf configuration.
configure ospf routerid 172.20.11.1
enable ospf
enable ospf export static Export_Statics
create ospf area 0.0.0.15
create ospf area 0.0.1.0
configure ospf add vlan XYZ area 0.0.0.0 passive
configure ospf add vlan XYZ-ABC area 0.0.0.0 passive
configure ospf vlan Default priority 0
configure ospf add vlan SITE1-SITE2 area 0.0.0.0 link-type point-to-point
configure ospf add vlan DATA area 0.0.0.0
configure ospf add vlan ROUTER-1-2 area 0.0.0.0 link-type point-to-point
configure ospf add vlan QWERTY area 0.0.0.0 passive
Photo of @ke
@ke
  • 162 Points 100 badge 2x thumb
how to config connect to cisco "cisco have > key chain "
Photo of andreas
andreas
So vlan SITE1-SITE2 is the area you have towards the ISP ?
How do your show ospf neig look like today ?
Photo of yuvi
yuvi
the site-2 is two cities linked by a LAN extension.
The ISP link is Router-1-2
sh ospf neighbor
Neighbor ID     Pri State                          Up/Dead Time                         Address
172.21.2.1      1    FULL      /DR      245:10:24:21/00:00:00:02             172.21.2.1
Im wondering EAPS has nothing to do with LSDB entries. IF my extreme switch is connected directly to the ISP CE router, then by default that router should be advertising all routes that are behind it in the MPLS. But the LSDB of the extreme router connected to the ISP CE router doesn't have any advertisements coming form that particular CE router.
Sumit Tokle, Alum
Can you provide "show version" command output and your contact phone number to discuss you about this issue?
Photo of yuvi
yuvi
Sumit, i have your email from a previous support ticket that you helped me on, so do you mind if i email you in case of doubts regarding this.. As of now i have narrowed it down to the ISP not advertising the routes. So i will be asking them to forward me the configuration of their CE router. Unless you think it could be a bug ?
any known bugs for OSPF in exos 12.5 ?
Sumit Tokle, Alum
go ahead ..
Sumit Tokle, Alum
what is your scenario?
Single home? (one router connected to another single ISP's router)(BGP not recommended)
Dual Home? (One or Multiple router connected to sing ISP routes)((BGP not recommended))
Multihoming? (Connected to two or more ISP?)
Dual Multihomming (Similar to Multihoming but with redundant link)
Photo of yuvi
yuvi
core router 1 ---> edge router 1 ---> ISP router 1 (MPLS)
core router 1 ---> edge router 2 ---> ISP router 2 (MPLS)
So our network has two ISP routers connected at each site, yet we only see one entry for each advertised route in the lsdb.
will send you an email with details of issue and network diagram.
Sumit Tokle, Alum
It was nice speaking with you Yuvi.
