OTDR Capabilities
  • Question
  • Updated 2 years ago
  • Answered
Anyone know Extreme plans to implement OTDR within XOS for layer 1 testing?
Photo of GCIT_Support
GCIT_Support
  • 510 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Drew C.
Drew C., Community Manager
  • 38,546 Points 20k badge 2x thumb
I'm not aware of any plans to add OTDR capability to the switch (though it is possible I wouldn't know...).  If anything, I would imagine this would be added to the optic itself, but that would likely make them prohibitively expensive.
After doing some searching, it doesn't appear this is very common to switching gear - separate equipment is almost always used for this kind of testing.
That said, if the optic you're using supports DDMI, you can view the Rx and Tx  power, as well as voltage, temp, and current.
# show port 32 transceiver information detail
Port : 32
Media Type : SF+_SR
Vendor Name : FINISAR CORP.
Part Number : FTLX8571D3BCL-EX
Serial Number : 1228P-<snip>
Wavelength : 850 nm
Temp (Celsius) : 41.15 Status : Normal
Low Warn Threshold : -8.00 High Warn Threshold : 73.00
Low Alarm Threshold : -13.00 High Alarm Threshold : 78.00
Voltage AUX-1/Vcc (Volts) : 3.34 Status : Normal
Low Warn Threshold : 3.00 High Warn Threshold : 3.60
Low Alarm Threshold : 2.90 High Alarm Threshold : 3.70
Tx Power (dBm) : -2.50 Status : Normal
Low Warn Threshold : -5.00 High Warn Threshold : -1.80
Low Alarm Threshold : -6.00 High Alarm Threshold : -0.80
Rx Power (dBm) : -4.06 Status : Normal
Low Warn Threshold : -18.01 High Warn Threshold : -1.00
Low Alarm Threshold : -20.00 High Alarm Threshold : 0.00
Tx Bias Current (mA): 8.09 Status : Normal
Low Warn Threshold : 5.00 High Warn Threshold : 10.80
Low Alarm Threshold : 4.00 High Alarm Threshold : 11.80
It's not TDR, but it's something.  Hope this helps!
-Drew
(Edited)
Photo of EtherMAN
EtherMAN, Embassador
  • 6,688 Points 5k badge 2x thumb
I saw some of this discussion on NANOG.. Drew you are spot on there are special optics for OTDR as it has to be able to send a pulse down the fiber and measure the amount of reflection and how long it took the reflected light to return.  Very specialized optics.  It would then need to have an algorithm to present the loss and findings to you via a web interface or something where you could see the splices and know the distance.  This would be a far stretch for any switch or router to do.... Heck I will settle for us being able to pull the DDMI info via a MIB :)
Photo of Drew C.
The DDMI/SNMP conversation came up again earlier today.  Other requests are coming in for it... hopefully it can be scoped for development.
Photo of Renato Santos
Renato Santos
  • 90 Points 75 badge 2x thumb
Drew, is it possible to receive the status of transceiver by snmp? What MIB imust be use?
Photo of Drew C.
Hi Renato,
Welcome to The Hub!
Unfortunately, support for receiving optics status over SNMP isn't available yet in EXOS.
Renato Santos
Thanks Drew
Renato Santos
Hello Drew!! I have another doubt.
How I could to check the Tx and Rx power in trnasceiver ports that haven ́t ddmi? (Switch Extreme X250 e)
Is it possible?
My boss want to monitor the port transceiver by SNMP in our NOC.
Thanks for your help.
Renato
Photo of Drew C.
Hi Renato,
This is something we've asked Engineering to take a look at.  It's becoming a more frequently requested feature.
See this thread for more information:  https://community.extremenetworks.com/extreme/topics/get-info-by-snmp-about-ports-trainciever-inform...
Renato Santos
Thanks Drew!
