Packet loss on directly connected node
  • Problem
  • Updated 1 year ago
  • Not a Problem
We have 2 switches interconnected and having 2 links on each switch all the links are having OSPF on P2P links from node and as well interlink of the switches. When we disable the OSPF on switch02 there is no packet loss but when enable it observed packet loss.
Tried to disable the ospf on Switch01 as well but still observing the packet loss, Configuration of ports are same on both sides. Kindly find below the configs i have on switches.
Swicth01
x_1           135  x.x.x.x    /30  -f-------o------------------- ANY    1 /1   VR-Default
x_3           136  x.x.x.x    /30  -f-------o------------------- ANY    1 /1   VR-Default
Interlink           338  x.x.x.x   /30  -f-------o------------------- ANY    1 /1   VR-Default
configure ospf routerid X.X.X.X
enable ospf
enable ospf export direct cost 10 type ase-type-1
enable ospf export static cost 10 type ase-type-1
create ospf area 10.0.0.0
configure ospf area 10.0.0.0 stub summary stub-default-cost 10
configure ospf add vlan x_1 area 10.0.0.0
configure ospf vlan x_1 priority 10
configure ospf add vlan x_3 area 10.0.0.0
configure ospf vlan Default priority 0
configure ospf add vlan Interlink area 0.0.0.0
configure ospf vlan Interlink priority 0
Swicth02
X_2           235  x.x.x.x    /30  -f-------o--------------B---- ANY    1 /1   VR-Default
x_4           236  x.x.x.x    /30  -f-------o------------------- ANY    1 /1   VR-Default
Neighbor ID     Pri State              Up/Dead Time             Address         Interface
          BFD Session State
x.x.x.x       0 FULL      /DROTHER 01:14:30:23/00:00:00:00  x.x.x.x     X_2
          None
x.x.x.x       0 FULL      /DROTHER 01:14:39:49/00:00:00:06  x.x.x.x     X_4
          None
X.X.X.X       1 FULL      /DR      01:14:47:43/00:00:00:08  X.X.X.X    Interlink
          None
Total number of neighbors: 3 (All neighbors in Full state)
Photo of waqas
waqas
  • 350 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Naresh
Naresh, Employee
  • 1,266 Points 1k badge 2x thumb
Hi Waqas,
Could you please let us know the platform, Exos version, port numbers, sharing algorithm, traffic details, OSPF status at the time of issue?
Also how you are confirming there is a packet loss.
