packet loss on summit 670 connected with LAG, MLAG ?
  • Question
  • Updated 3 years ago
  • Answered
Strange problem with packets loss. I have LAG on port 47-48 connected to 2 different switches with MLAG. I see problem only between pair:
src mac  f0:1f:af:d7:b5:37  and dst  mac  00:18:9d:08:c8:59 rest of traffic are ok.
Summit sees in fdb table dst mac on port 47 but he sends via port 48 ( according to counters on port 47,48).. On next switch (uplink, also summit) i can't see any packets ( checked by port mirroring and ingress counters)
If i disable port 48 all works correct. If i change src mac address on server - all works also correct.
There is  some well known bug in hashing in LAG/MLAG in 15.3.1.4 v1531b4-patch1-18 ?
What has higher precedence when switch have to choose wich port use to send: entry in fdb or hash alghoritm ?
 some outputs:
 Summit8.48 # show fdb 00:18:9d:08:c8:59
Mac Vlan Age Flags Port / Virtual Port List
00:18:9d:08:c8:59 vlan183(0183) 0041 d m 47
* Summit8.49 # debug hal show fdb | include 00:18:9d:08:c8:59
00:18:9d:08:c8:59 183 00001021 47 TRUE FALSE
* Summit8.65 # show policy trampek
Policies at Policy Server:
Policy: trampek
entry test4 {
if match all {
ethernet-source-address f0:1f:af:d7:b5:37;
then {
log ;
count trampek4 ;
permit ;
Number of clients bound to policy: 1
Client: acl bound once
Summit8.62 # show access-list counter ports 47 48 egress
Policy Name Vlan Name Port Direction
Counter Name Packet Count Byte Count
trampek * 47 egress
trampek4 0
trampek * 48 egress
trampek4 10
Image : ExtremeXOS version 15.3.1.4 v1531b4-patch1-18
 enable sharing 47 grouping 47-48 algorithm address-based L3_L4 lacp
thanks for help,
Pedro
Photo of Pedro
Pedro
  • 322 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Chad Smith
Chad Smith, Alum
  • 5,640 Points 5k badge 2x thumb
Official Response
Pedro,
The EXOS software version you are running is susceptible to a known defect that can cause traffic forwarding problems:
PD4-4490184741:Traffic loss occurs on switches due to parity errors in L3 table.
With this issue only certain traffic flows will be affected (as you have described.  To confirm this issue a debug session with the GTAC would be required.
PD4-4490184741 was corrected in 15.3.1.4patch1-36.  However, the current recommended software version for the X670 platform is EXOS 15.5.4.2-patch1-5.xos.
(Edited)
Photo of Chad Smith
Chad Smith, Alum
Official Response
I have created a GTAC Knowledge article that provides further information on these software defects: Traffic loss due to parity errors
