Packet loss to AP's
  • Problem
  • Updated 3 years ago
  • In Progress
I have a problem with my Ap's 3865e. Access points are connected to catalyst 2960x. When I try to ping the switch I haven't packet loss.
There are packet loss if I ping my access point.
Link between AP and switch is tested and it [link] is good.
Photo of Alexander
Alexander
  • 140 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 44,984 Points 20k badge 2x thumb
could you check the switchport - is the status for speed/duplex 1G/full ?
Photo of Alexander
Alexander
yes, it is.
AP have next config -
vlan settings - untagged
IP Address Assignment - Use DHCP
Ethernet Port - auto /1500
and catalyst -
interface GigabitEthernet1/0/7
 switchport trunk native vlan 10
 switchport trunk allowed vlan 10,12
 switchport mode trunk
(Edited)
Photo of Andre Brits Kannemeyer
  • 4,980 Points 4k badge 2x thumb
Do you see the same packet loss if you ping from the AP via SSH?
Are you trying to ping between the AP and switch from within the same subnet?
Photo of Alexander
Alexander
If i try to ping from the AP to EWC/switch/router I have not packet loss.
The  EWC located on a lan "A". Let it be Vlan 1. AP's located on a lan "B". It is Vlan 10. Switch - Vlan 15.
On more problem -  connected clients have  rtt from 1ms to 200-300ms.
