PacketFence and Summit switches
  • Question
  • Updated 4 years ago
                Sorry for the amount of detail, but we are trying to setup PacketFence with our Summit switches and I think everything looks fine on the PacketFence side, but I keep getting the following on the test switch:
07/30/2014 13:47:39.42 <Info:nl.ClientAuthFailure> Slot-1: Authentication failed for Network Login MAC user 3C970EADB66B Mac 3C:97:0E:AD:B6:6B port 5:13
07/30/2014 13:47:39.42 <Warn:AAA.RADIUS.noServResp> Slot-1: No response from server 172.22.0.3 trying local.
07/30/2014 13:47:39.42 <Warn:AAA.RADIUS.noServerResp> Slot-1: No servers responding
07/30/2014 13:47:36.42 <Warn:AAA.RADIUS.resendPkt> Slot-1: Resend request to Authentication Server address 172.22.0.3 current request count is 2
07/30/2014 13:47:33.41 <Warn:AAA.RADIUS.resendPkt> Slot-1: Resend request to Authentication Server address 172.22.0.3 current request count is 1
What steps can I perform on the switch to verify connectivity?  I can ping/trace to the PacketFence server from the switch.
We have PacketFence installed on a server (172.22.0.3).  We have three interfaces defined in PacketFence: Management (172.22.0.3/23), Isolation (12.22.2.3/23), and Registration (172.22.38.3/23).  Those interfaces are plugged into our core Extreme Networks Summit switch into matching VLANs: “Internal_Appliances” (172.22.0.1/23), “MAC_Isolation” (172.22.2.1/23), and “MAC_Registration” (172.22.38.1/23).
 That switch is then uplinked to our desktop switch, where we have created a “MAC_Isolation” (172.22.2.2/23), “MAC_Registration” (172.22.38.2/23), MAC_Temp (no IP), and “Desktops” (172.22.34.2/23).  We want the ports to eventually end up in the “Desktops” VLAN after authorization.
                 The steps below were performed on the Extreme switch to which the desktops are connected, using Port 5:13 as our test.
create vlan MAC_Registration
config vlan "MAC_Registration" tag 369
create vlan MAC_Temp
enable snmp access
configure snmp add trapreceiver 172.22.0.3 community public vr VR-DEFAULT
configure vlan MAC_Registration add ports 5:13 untagged
configure ports 5:13 vlan MAC_Registration lock-learning
disable snmp traps port-up-down ports 5:13
configure radius netlogin primary server 172.22.0.3 1812 client-ip 172.22.32.2 vr VR-Default
configure radius netlogin primary shared-secret (password)
enable radius netlogin
configure netlogin vlan MAC_Temp
enable netlogin mac
configure netlogin dynamic-vlan enable
configure netlogin dynamic-vlan uplink-ports 4:45
configure netlogin mac authentication database-order radius
enable netlogin ports 5:13 mac
configure netlogin ports 5:13 mode port-based-vlans
configure netlogin ports 5:13 no-restart
      The results of “show netlogin” and “show radius” on the switch returns the following:
Slot-1 Stack.4 # show netlogin
NetLogin Authentication Mode : web-based DISABLED;  802.1x DISABLED;  mac-based ENABLED
NetLogin VLAN                : "MAC_Temp"
NetLogin move-fail-action    : Deny
NetLogin Client Aging Time   : 5 minutes
Dynamic VLAN Creation        : Enabled
Dynamic VLAN Uplink Ports    : 4:45
        Web-based Mode Global Configuration
Base-URL                 : network-access.com
Default-Redirect-Page    : ENABLED; http://www.extremenetworks.com
Logout-privilege         : YES
Netlogin Session-Refresh : ENABLED; 3 minute(s) 0 second(s)
Refresh failures allowed : 0
Reauthenticate on refresh: Disabled
Authentication Database  : Radius, Local-User database
Proxy Ports              : 80(http),443(https)
        802.1x Mode Global Configuration
Quiet Period                    : 60
Supplicant Response Timeout     : 30
Re-authentication period        : 3600
Max Re-authentications          : 3
RADIUS server timeout           : 30
EAPOL MPDU version to transmit  : v1
          MAC Mode Global Configuration
MAC Address/Mask      Password (encrypted)            Port(s)
Default               <not configured>                any
Re-authentication period        : 0 (Re-authentication disabled)
Port: 5:13,  Vlan: MAC_Registration,  State: Enabled,  Authentication: mac-based
Guest Vlan <Not Configured>: Disabled
Authentication Failure Vlan <Not Configured>: Disabled
Authentication Service-Unavailable Vlan <Not Configured>: Disabled
MAC                IP address       Authenticated     Type    ReAuth-Timer   User
3c:97:0e:ad:b6:6b  0.0.0.0          No                MAC     0
(B) - Client entry Blackholed in FDB
Number of Clients Authenticated  : 0
Slot-1 Stack.5 # show radius
Switch Management Radius: disabled
Switch Management Radius server connect time out: 3 seconds
Switch Management Radius Accounting: disabled
Switch Management Radius Accounting server connect time out: 3 seconds
Netlogin Radius: enabled
Netlogin Radius server connect time out: 3 seconds
Netlogin Radius Accounting: disabled
Netlogin Radius Accounting server connect time out: 3 seconds
Primary Netlogin Radius server:
    Server name   :
    IP address    :  172.22.0.3
    Server IP Port:  1812
    Client address:  172.22.38.2 (VR-Default)
    Shared secret :  2\q;sJ;@F=8Bjn
Access Requests   :  13752           Access Accepts    :  0
Access Rejects    :  0               Access Challenges :  0
Access Retransmits:  9168            Client timeouts   :  4584
Bad authenticators:  0               Unknown types     :  0
Round Trip Time   :  0
Photo of Stephen Stormont
Stephen Stormont
  • 822 Points 500 badge 2x thumb
Posted 4 years ago
Photo of Tyler Marcotte
Tyler Marcotte, Official Rep
  • 2,740 Points 2k badge 2x thumb
Stephen,
I would start by running packet capture on the interface of the PacketFence and seeing if you get a RADIUS request there from the switch. If you are not getting a request, then there is a problem network connectivity and you should try 'ping vr "VR-Default" 172.22.0.3 from 172.22.38.2'
If you are getting RADIUS requests on the Packetfence interface then most likely the packetfence server isn't set up properly to accept the RADIUS requests. I haven't used Packetfence myself, but I would check the area where you configure RADIUS clients and ensure the shared secret is correct and that the correct Switch IP is added.
Tyler
Stephen Stormont
I jumped right into the ping step and the command that you gave me failed.  On the switch with the 172.22.38.2 VLAN there is also a VLAN that is 172.22.0.2/23 and pinging from that worked.
How can I further troubleshoot why the communication is failing from the 172.22.38.2 address?
Slot-1 Stack.4 # ping vr "VR-Default" 172.22.0.3 from 172.22.38.2
Ping(ICMP) 172.22.0.3: 4 packets, 8 data bytes, interval 1 second(s).
--- 172.22.0.3 ping statistics ---
4 packets transmitted, 0 packets received, 100% loss
round-trip min/avg/max = 0/0/0 ms
Slot-1 Stack.5 # ping vr "VR-Default" 172.22.0.3 from 172.22.0.2
16 bytes from 172.22.0.3: icmp_seq=0 ttl=64 time=1.985 ms
16 bytes from 172.22.0.3: icmp_seq=1 ttl=64 time=1.832 ms
16 bytes from 172.22.0.3: icmp_seq=2 ttl=64 time=1.894 ms
16 bytes from 172.22.0.3: icmp_seq=3 ttl=64 time=14 ms
4 packets transmitted, 4 packets received, 0% loss
round-trip min/avg/max = 1/5/14 ms
My initial guess would be there there is no route between the two addresses and therefore they cannot communicate. You can try the traceroute command to find out where the communication stops. Wherever it stops is most likely where the route is missing. One option that you can try would be to change your RADIUS client settings so that the RADIUS request comes from the directly connected interface. This would look like this:
configure radius netlogin primary server 172.22.0.3 1812 client-ip 172.22.0.2 vr VR-Default
That would make the RADIUS request come from the 0.2 address instead of the 38.2 address.
Stephen Stormont
We got this working finally, but now we realized that this method won't allow us to Wake On LAN unless someone has another solution.
Basically, devices are put int the "MAC_Temp" VLAN when powered off which appears to be a L2 VLAN that we can't forward anything to.  Does anyone have any solutions on how to work around that?
Also, it looks like 802.1x instead of mac based authentication might allow WOL to work?
Try using 'configure netlogin ports <ports> allow egress-traffic all_cast'. This will allow all traffic to egress a port while in the unauthenticated state.
Stephen Stormont
That allows traffic out of the port, but it doesn't help with routing the WOL packet to the device on the port.
Sorry, I'm not familiar with the way that packet fence operates, however, if it's not routable, then there most likely wouldn't be a way to get a WOL packet to that device unless it's on the same VLAN.
