Password Recovery Extreme Switches
  • Problem
  • Updated 4 months ago
  • Not a Problem
Hi All,
I have a customer and he 3 Extreme Switches. He don't know the Username and password for his switches because the one who configured the switches is not here now. I want to reset the Username and Password via console cable. I found some blogs here in community but i am afraid from configuration reset, I want to know the method mentioned here will effect my current configuration or not.
Photo of Waseem Ullah
Waseem Ullah
  • 122 Points 100 badge 2x thumb
Posted 4 months ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,054 Points 20k badge 2x thumb
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,402 Points 5k badge 2x thumb
if your colleague was not "educated" then most probably you will have user account with default password. it is worth to try instead of "admin" use "user".
(Edited)
Photo of Alexandr P
Alexandr P, Embassador
  • 11,666 Points 10k badge 2x thumb
Hello, Waseem Ulah!
You can access to switch with default account from BootRom:
BootRom > config none
BootRom > boot
After that you can access to switch with login "admin", password - none.
Then you can download configuration file, add lines with new account and upload to switch.
Thank you!
Photo of Doug Hyde
Waseem,
Are you all set? Did these suggestions answer your question?
Waseem Ullah
Thanks to all for your suggestions. I will visit the customer soon and check what you guys suggest. Then i will update here.
