Per VLAN RSTP Configuration
  • Question
  • Updated 3 years ago
  • Answered
Create Date: Mar 13 2013 9:14PM
Hi Im pretty confused with the way how to configure Per vlan spanning tree on XOS because of the way extreme uses spanning tree domains. Can someone please post a sample configuration on how it would look if you would want RSTP betwen a cisco and a extreme summit switch?
(from Samueltechking)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Mar 28 2013 3:05PM
Its been a while since you posted this, but you could try setting the encapsulation mode of the port connecting to Cisco as pvst-plus?
* X250e-24p.2 # con <stpd-name>  add <vlan-name> ports <uplink port/trunk port>
  <cr>            Execute the command
  dot1d           802.1d mode
  emistp          EMISTP mode
  pvst-plus       PVST-Plus mode
(from Shashank_S Kumar)
Photo of Merab Katibashvili
Merab Katibashvili
  • 112 Points 100 badge 2x thumb
i have Cisco L3 3560 and two extreme switch X430 connected. L3 Switch do it rstp and what configuration make it on extreme sw please write me configuration RSTP
Photo of Colatuno, Joe
Colatuno, Joe, Escalation Support Engineer
  • 1,096 Points 1k badge 2x thumb
Hey Merab,
Below is example of dot1w interoperability with Cisco:
Extreme Configuration (EXOS)
configure vlan test add port 3 tagged
conf vlan "Default" del port 3
create stpd domain_test
conf stpd "domain_test" add vlan "test" ports 1,3 pvst-plus
conf stpd "domain_test" tag 10
con stpd "domain_test" mode dot1w
conf stpd "domain_test" default-encapsulation pvst-plus
conf stpd "domain_test" ports link-type point-to-point 1,3
enable stpd "domain_test"
disable edp port 3
save
Cisco Configuration (IOS)
configure terminal
interface gigabitEthernet 0/3
no cdp enable
switchport trunk encapsulation dot1q
switchport mode trunk
switchport nonegotiate
no shutdown
end
configure terminal
spanning-tree vlan 10
spanning-tree mode pvst
spanning-tree extend system-id
end
copy run start
(Edited)
