Perimeter Switch Recommendation: Which Model should I use?
  • Question
  • Updated 3 years ago
Need to support: 10/100/1000BASE-T (RJ-45), SPF+ GBIC, out-of-band management port, GBP, VRRP and IP Tunneling. Got any suggestions?
Photo of Matt Tinonga
Matt Tinonga
  • 372 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 12,754 Points 10k badge 2x thumb
Hi Matt,
Depending on the number of BGP routes needed, either the X480 or the X460-G2 would probably be a good fit for you needs.
