Phones dropping out and not reconnecting to wifi AP's (Not roaming)
  • Question
  • Updated 2 years ago
  • Answered
I'm having a weird problem here and I'm not sure if it's related to either my AP's or my Spectralink phones.
For some reason the phones seems to connect all fine and find their provisioning server but do not roam in between AP's which means I'm locked to one AP. The moment I go out of range and in-range of another AP the device drops off and reconnects which results in losing the call.
I honestly have no idea where to even begin troubleshooting this so any advice is appreciated.
-Tom
Photo of Tom Taylor
Tom Taylor
  • 804 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,140 Points 20k badge 2x thumb
 I would suggest opening a ticket with the GTAC so your configurations can be reviewed.  https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Tec...
Photo of MANAS BEHERA
MANAS BEHERA
  • 210 Points 100 badge 2x thumb
Hello,
Which Band you are using ?  If you are using 2.4 GHz then it is not recommended for voice traffic. I suggest you to test the voice quality in 5 GHz.
Regards,
Manas Ranjan
+91 9619551266
