physical loop messages on BD8810
  • Question
  • Updated 2 years ago
  • Answered
All nodes and associations are fluctuating very frequently
01/22/2017 13:23:39.40 <Warn:IPMC.Warning> MSM-A: Our own packet received. Mac address of the received packet is [0:4:96:52:5c:38],there could be physical loop in the network
01/22/2017 13:23:39.40 <Warn:IPMC.Warning> MSM-A: Previous message repeated 3 additional times in the last 1 second(s)
01/22/2017 13:21:04.65 <Warn:IPMC.Warning> MSM-A: Our own packet received. Mac address of the received packet is [0:4:96:52:5c:38],there could be physical loop in the network
01/22/2017 13:21:04.64 <Warn:IPMC.Warning> MSM-A: Previous message repeated 3 additional times in the last 1 second(s)
01/22/2017 13:21:01.65 <Warn:IPMC.Warning> MSM-A: Our own packet received. Mac address of the received packet is [0:4:96:52:5c:38],there could be physical loop in the network
01/22/2017 13:21:01.63 <Warn:IPMC.Warning> MSM-A: Previous message repeated 3 additional times in the last 1 second(s)
01/22/2017 13:23:28.69 <Erro:STP.InBPDU.Drop> MSM-A: Port=4:27: No associated STP port for STP Domain tag 1 (Rate-limited)
01/22/2017 13:23:17.09 <Info:vlan.msgs.portLinkStateDown> MSM-A: Port 7:5 link down
Photo of waqas
waqas
  • 350 Points 250 badge 2x thumb
Posted 2 years ago
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
Did you connect the mgmt port to the front ports ?
Photo of waqas
waqas
mgmt port is down
Photo of waqas
waqas
we have different nodes connected in different vlans, the image in use is 15.1.3.4
Photo of OscarK
OscarK, ESE
I would check for a physical loop with ELRP on all vlans.
Photo of waqas
waqas
 sh elrp
ELRP Standalone Client:       Enabled
Number of ELRP sessions:          2
Number of ELRP pkts transmitted:  5963055
Number of ELRP pkts received:     0
                                                Pkts     Pkts            Disable
Client  Vlan        Ports  Int.    Count Cyclic Xmit     Rcvd     Action Port (sec)
CLI     MobileRadio  All   10       0     Yes    75981     0         L     -
CLI     SS7_2        All   10       0     Yes    1131338   0         L     -
Action : (P) Print , (L) Log , (T) Trap , (C) Callback
Photo of OscarK
OscarK, ESE
Photo of waqas
waqas
So you think its a Software Bug
Photo of OscarK
OscarK, ESE
Yes, although part of it something in the network forwarding the general query with the original mac address as source which is something that normally does not happen.
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
use elrp one shot to test for a loop on other VLANS. Unless you only have 2 VLANS.
