PIM-SM Advanced Edge License
  • Question
  • Updated 2 years ago
  • Answered
What's wrong?
ExtremeXOS Advanced Edge License Features:
PIM-SM-Edge (limited to max of 2 active interfaces)
configure pim add vlan "DownlinkUn" sparse
enable pim
* X450a-24t.26 # configure pim crp vlan DownlinkUn multicast
Error: This command cannot be executed at the current license level.
* X450a-24t.27 # sh licenses
Enabled License Level:
Advanced Edge
Enabled Feature Packs:
None
Photo of Andrew Zhukov
Andrew Zhukov
  • 110 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Andrew,
When using PIM-SM-Edge the switch cannot be configured as CRP or CBSR.
Photo of Henrique
Henrique, Employee
You need the Rendezvous point and Bootstrap router elected in a device with Core license.
Andrew Zhukov
Perfect. Write this limitation in the manual.
Andrew Zhukov
I find 2 conversation regarding  advanced edge license here. Detailed explanation about 2 vlans. And nothing more about other limitations.
Photo of Henrique
Henrique, Employee
Hi Andrew, you can find the information below in 16.1 User Guide:
PIM Edge Mode is a subset of PIM that operates with the following restrictions:
- The switch does not act as a candidate rendezvous point (CRP).
- The switch does not act as a candidate bootstrap router (CBSR).
- At most, four active PIM-SM interfaces are permitted. There is no restriction on the number of
passive interfaces (within the limit of the maximum IP interfaces).
Note that you can have up to 4 interfaces instead of 2.
Please let me know what version you are using then I can track this information.
Thanks.
Andrew Zhukov
Sales rogue :(
I find this record in the manual.
ExtremeXOS version 12.6.3.2 v1263b2 I'm Not going to change something.
I have the fully functional switch with Core license on another locaton.  I'll try to setup this one without CRP.
Photo of Henrique
Henrique, Employee
Hi Andrew, using another switch with Core License is enough to have PIM-SM working.
Only one RP/CBSR is need. However, if you have 2 switches with Core License you can use both with CRP/CBSR configuration for redundancy purpose.
Andrew Zhukov
Thanks. I understood.
