plugging 10G port interface modules to a X460
  • Question
  • Updated 4 years ago
I need to add a couple of 10 G interface modules XGM3SB-4SF to an X460. do you know if I need to reboot the switch in order for it to detect these modules
thanks
Ahmed
Photo of Ahmed Bortai
Ahmed Bortai
  • 80 Points 75 badge 2x thumb
Posted 4 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
Ahmed,
Although you can plug the module into the switches while powered on, in order for the XOS to see them you need to reboot the switch.  Please make sure you are using a version of code 15.1.x or later along with Boot rom 2.0.1.7 or later as well.
Bill
Ahmed Bortai
Thanks Bill.
Why is it needed to have this version of XOS and BootRom
Ahmed
It is not for specifics on the 2-Port card, but there was a lot of work done on CPU efficiency in XOS with that combination of code.  The recommendation is that you use that firwmaware/bootrom or later.
