PoE during switch B3/B5 bootup
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
We were doing some testing and noticed that during bootup of our B3 and B5 switches, PoE comes on twice early in boot, before going off for a few minutes and then staying on permanently. This is a bit of a problem as our Crestron AV controllers enter setup mode after being power cycled several times in a short period, which can happen during RCD testing.
To be specific, PoE comes on at about 5 seconds after the switch turns on, briefly drops about 23s, comes back on and then turns off about 32s, then stays off until at least a minute after, depending on model. Looking at the console this happens during the bootloader, so I doubt there's any configuration changes I can make. Is this expected behaviour?
We are looking at UPS or a change in RCD testing procedure to isolate the circuit the switch is on.
Photo of James A
James A, Embassador
  • 7,338 Points 5k badge 2x thumb
Posted 2 years ago
Photo of Mike D
Mike D, Alum
  • 3,852 Points 3k badge 2x thumb
Hello James,
re: Is this expected behaviour?
It will take few days into next week - but I'll investigate this and will get back to you.
Regards,
Mike
Photo of Mike D
Mike D, Alum
I still owe you a follow up on this thread James.  I haven't forgotten.
I'l update when I have a definitive answer.  Sorry for the delay.
Mike
Photo of Mike D
Mike D, Alum
Hello James,
We've confirmed this SecureStack POE behavior is expected as part of the hardware test sequence at boot.
There are no configurable parameters to tune this behavior.
Regards,
Mike
