PoE injector for Enterasys 3705i WAP
  • Question
  • Updated 3 years ago
  • Answered
I want to put a 3705i AP in a remote office but the switch is an Enterasys A series and does not have PoE - does anyone know of a compatible PoE injector? Or a few to choose from?
Photo of Justin Blackburn
Justin Blackburn
  • 184 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
It should work with any PoE adapter that is 802.3af compatible.
I like the ones from PowerDsine - if you need a one port that one is good..
http://www.amazon.com/PowerDsine-3001G-port-15-4-Injector/dp/B00GOFWL66/ref=sr_1_8?s=electronics&...
Or you order one from Extreme :-)
Justin Blackburn
Perfect, thank you!
Photo of Norman Tan
Norman Tan
  • 170 Points 100 badge 2x thumb
Hi does the poe injector comes with power cord when purchased?
Single Port 1 Gigabit 802.3AF PoE Midspan
No power cord included.
-Ron
Here the part number of the PoE injector in case someone is looking for it...
PD-3501G-ENT
or the one with PoE+.....
PD-9001GR-ENT
Single Port 1 Gigabit 802.3AT PoE Midspan
Photo of Norman Tan
Norman Tan
So Basically i have to purchase additional power cord separately add on POE injector PD-3501G-ENT
Correct,  the part is send to different regions and it wouldn't make much sense to include a power cord for North America .... which "we" in Europe just throw in the recycle bin :-)
Photo of Norman Tan
Norman Tan
You are so right, Thank you so much.
