POE issues switches, suddently POE is going dead, we need to do manualy "disable & enable inline-power slot " for it work
  • Question
  • Updated 2 years ago
  • Answered
POE issues in x440, x460 switches, suddently POE is going dead, we need to do manualy "disable inline-power slot " and "enable inline-power slot " for it work
Photo of Avinash Paul
Avinash Paul
  • 70 Points
Posted 2 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,468 Points 5k badge 2x thumb
Hi Avinash,
Can you share the logs taken during the failure is any?
"show log" and "show log messages nvram"
Also what is the EXOS version running in the switch? "show switch",  "show version" and "show stacking"
Does this happen only after a slot/switch reboot or during normal operations?
