PoE problem urgent
  • Question
  • Updated 5 years ago
Create Date: Sep 30 2013 9:24AM
I am facing a problem with a stack of Summit X460-48p switches relating to PoE. The stack is 6 nodes deep and is running XOS 15.0 or 1 from memory. I am not sure of the exact version of the bootrom.
I faced what appears to be a one off situation where the ports (default configured to deliver 15W dropped to 5W) across the stack and the power budget (max usage threshold dropped from 70 to 50%). The problem was not with a specific node but was across the stack.
I am aware of any problems with the power feed. Each of the nodes is provisioned with a single PSU. What I found is that devices that required less than the 5W continued functioning and the stack itself appeared to be normal but devices requring more than 5W obviously would not function.
I am worried if this can be triggered across other stacks running similar code. Once I set the port budget and power limit to the normal it started working and has been stable since. Are there any known issues with PoE as a process.
This is urgent . What could cause this problem. I know that there were issues with PoE with the earlier series of XOS (12 series). Any sugesstions would be appreciated. Thank you.
(from Anush_Santhanam)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Sep 30 2013 2:15PM
Hello Excalibur
I have not seen this issue with anything 15 or higher however TAC would know better and can look at the show tech etc.
I will see if I can find anything but would suggest opening a case with TAC as well.
Thanks
P
(from Paul_Russo)
Create Date: Oct 17 2013 11:37AM
Thank you so much for the reply. I have been investigating this in the background and have also spotted the following in the logs
1. The power budget seems to have dropped to 50% from the default 70
2. I am seeing logs relating to the stack (stack messages)
3. EDP neighbor removed and then added
4. EAPS messages
I am wondering if this is because of the master switch malfunctioning that could be causing problems with the POE across the stack. Can you please get back to me.
