Port channel with C3560 cisco switch
  • Question
  • Updated 3 years ago
  • Answered
I need to setup a port channel with a Cisco switch. I just want to verify the steps I need to perform.
This is what I have on the Cisco side for the port channel config so far:
interface Port-channel1
description Etherchannel to summit
switchport trunk encapsulation dot1q
switchport mode trunk
interface GigabitEthernet0/49
description Trunk to summit GI2/1
channel-group 1 mode desirable
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
On the extreme side:
en sharing 1:48 grouping 1:48,2:48,3:48,4:48 lacp
con port 1:48 des port_channel_cisco
Then I would just remove ports from default vlan:
con default del port 1:48,2:48,3:48,4:48
Then add them to my vlans
con server add port 1:48,2:48,3:48,4:48 untagged
etc.....
Photo of HED Admin
HED Admin
  • 132 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Marcus Florido
Marcus Florido
  • 350 Points 250 badge 2x thumb
The cisco is going to want to negotiate the port channel/LAG via PaGP.  The industry standard for this protocol is LACP, which you'll want to make sure and specify on the cisco.  In your channel-group command, replace "desirable" with "active".  This will let the cisco know to use LACP instead of PaGP, and your LAG should be negotiated and work just fine.
Photo of HED Admin
HED Admin
I can't ping across this new port channel?  I do a summary and it looks up.  Ideas?
Photo of HED Admin
HED Admin
Marcus Florido
Funny, never had a problem creating a LAG between Extreme/Enterasys, Enterasys/Juniper, Juniper/Extreme, or any other vendor.  Apparently the Cisco is the oddball here.  Glad you got it figured out.
