Port problem with SecureStack B3 B3G124-24P
  • Question
  • Updated 3 years ago
  • Answered
Hi. I have a surplus B3G124-24P switch. I make all the all resets and factory defaults  ( reset passwords, clear config all, load the last firmware version ( thru the console ) , etc. ).
I have console access with no problem.  The diagnostics leds apparently are all ok.But when I connect any device in the any  port of the switch, the light of the port don’t light and the port in not up.
I assign Ip address to the device, and the rest of the different stating up configuration of the starting guide, but not success. No pings of any station.
Other problem is I can’t view or delete the files in the nvram, I have a error msg.
I put the basic info about this, the  operational status of the ports  is down. And the switch is completly inoperational
Thanks
Miguel
Telcom engineer / IT sysadmin /  Tech Teacher
Elche Alicante Spain
<code>
Enterasys SecureStack B3
Enterasys Networks, Inc.
50 Minuteman Rd.
Andover, MA 01810-1008 U.S.A.
Phone: +1 978 684 1000
E-mail: support@enterasys.com
WWW: http://www.enterasys.com
(c) Copyright Enterasys Networks, Inc. 2010
Chassis Firmware Revision:  06.03.09.0005
B3(su)->show port status
          Alias        Oper    Admin   Speed
Port      (truncated)  Status  Status  (bps)     Duplex  Type
ge.1.1                 Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.2                 Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.3                 Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.4                 Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.5                 Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.6                 Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.7                 Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.8                 Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.9                 Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.10                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.11                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.12                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.13                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.14                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.15                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.16                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.17                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.18                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.19                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.20                Down    Up      N/A       N/A     BaseT RJ45/PoE
ge.1.21                Down    Up      N/A       N/A     Combo RJ45/SFP/PoE
ge.1.22                Down    Up      N/A       N/A     Combo RJ45/SFP/PoE
ge.1.23                Down    Up      N/A       N/A     Combo RJ45/SFP/PoE
ge.1.24                Down    Up      N/A       N/A     Combo RJ45/SFP/PoE
lag.0.1                Down    Up                        lag
lag.0.2                Down    Up                        lag
lag.0.3                Down    Up                        lag
lag.0.4                Down    Up                        lag
lag.0.5                Down    Up                        lag
lag.0.6                Down    Up                        lag
B3(su)->show port
Port  ge.1.1 enabled
Port  ge.1.2 enabled
Port  ge.1.3 enabled
Port  ge.1.4 enabled
Port  ge.1.5 enabled
Port  ge.1.6 enabled
Port  ge.1.7 enabled
Port  ge.1.8 enabled
Port  ge.1.9 enabled
Port  ge.1.10 enabled
Port  ge.1.11 enabled
Port  ge.1.12 enabled
Port  ge.1.13 enabled
Port  ge.1.14 enabled
Port  ge.1.15 enabled
Port  ge.1.16 enabled
Port  ge.1.17 enabled
Port  ge.1.18 enabled
Port  ge.1.19 enabled
Port  ge.1.20 enabled
Port  ge.1.21 enabled
Port  ge.1.22 enabled
Port  ge.1.23 enabled
Port  ge.1.24 enabled
Port  lag.0.1 enabled
Port  lag.0.2 enabled
Port  lag.0.3 enabled
Port  lag.0.4 enabled
Port  lag.0.5 enabled
Port  lag.0.6 enabled
B3(su)->dir
Images:
Filename:      b3-series_06.03.04.0004
Version:       06.03.04.0004
Date:          Fri Mar 26 14:38:49 2010
CheckSum:      d27b264faa18b6dd5767661bb4c383c1
Compatibility: B3G124-24, B3G124-24P, B3G124-48, B3G124-48P
Filename:      b3-series_06.03.09.0005 (Active) (Boot)
Version:       06.03.09.0005
Date:          Mon Dec 20 15:34:12 2010
CheckSum:      9dc814b916e36f5d20f0232656ba2d0e
Files:                           Size
configs:
HiPath.cfg                       4197
Ini_HiPath.cfg                   4197
Entorno_HiPath.cfg               4197
2010-03-10.cfg                   14437
Test_TFCA.cfg                    12389
JC-2010-03-22.cfg                12389
logs:
current.log                      512017
show config
This command shows non-default configurations only.
Use 'show config all' to show both default and non-default configurations.
begin
#***** NON-DEFAULT CONFIGURATION *****
# Firmware Revision:  06.03.09.0005
#ip
set ip address 192.168.0.85 mask 255.255.255.0 gateway 0.0.0.0
#system
set switch member 1 6
#vlan
#Router Configuration
#arp
#arpinspection
#authentication
#banner
#cdp
#ciscodp
#console
#diffserv
#dhcps
#dhcpsnooping
#eapol
#flowcontrol
#garp
#gvrp
#history
#igmp
#inlinepower
#ipv6
#lacp
#length
#lldp
#linkflap
#logging
#logout
#mac
#macauthentication
#maclock
#mtu
#multiauth
#newaddrtrap
#nodealias
#cos state
#cos port-config
#cos port-resource
#port
#prompt
#sflow
#radius
#rmon alarm
#rmon capture
#rmon channel
#rmon event
#rmon filter
#rmon history
#rmon stats
#snmp
set snmp access ro security-model v1 exact read All notify All nonvolatile
set snmp access ro security-model v2c exact read All notify All nonvolatile
set snmp access public security-model v1 exact read All write All notify All nonvolatile
set snmp access public security-model v2c exact read All write All notify All nonvolatile
set snmp access public security-model usm exact read All write All notify All nonvolatile
set snmp community :3fb03022e4966512343b511c263dcf1240739359ec6cad7d8c6277007e7e0657521e0641967b150156:
set snmp group ro user ro security-model v1
set snmp group public user public security-model v1
set snmp group ro user ro security-model v2c
set snmp group public user public security-model v2c
set snmp group public user public security-model usm
set snmp user public authentication md5 :07edcc4d0db67303c5b7c28d3538521d: encryption des privacy :07edcc4d0db67303c5b7c28d3538521d:
set snmp view viewname All subtree 1
#sntp
#spantree
#ssh
#ssl
#summertime
#tacacs
#telnet
#tftp
#timezone
#vlanauthorization
#webview
#width
end
B3(su)->show config all
begin
#***** ALL (DEFAULT and NON-DEFAULT) CONFIGURATION *****
#ip
set ip protocol none
#system
set switch description 1 "Enterasys Networks, Inc. B3 -- Model B3G124-24P"
set system fault-bias default trap disable
set system temperature syslog disable trap disable overtemp-threshold 100
set system utilization threshold 800
set system password length 8
set system lockout attempts 3
set system lockout time 15
set system password aging disable
set system password history 0
set system enhancedbuffermode disable
set system hostprotect disable
#vlan
set vlan egress 1 ge.1.1-24;lag.0.1-6 untagged
set host vlan 1
router
enable
configure
license advanced
arp timeout 14400
no ip dvmrp
 no ip igmp
no ip pimdm
no ip pim-trapflags
ip routing
ip icmp redirect enable
router rip
exit
router vrrp
exit
exit
exit
exit
#arp
#arpinspection
set arpinspection vlan 1-4093 logging
clear arpinspection validate src-mac dst-mac ip
set arpinspection trust port ge.1.1 disable
set arpinspection limit port ge.1.1 rate 15 burst interval 1
set arpinspection trust port ge.1.2 disable
set arpinspection limit port ge.1.2 rate 15 burst interval 1
set arpinspection trust port ge.1.3 disable
set arpinspection limit port ge.1.3 rate 15 burst interval 1
set arpinspection trust port ge.1.4 disable
set arpinspection limit port ge.1.4 rate 15 burst interval 1
set arpinspection trust port ge.1.5 disable
set arpinspection limit port ge.1.5 rate 15 burst interval 1
set arpinspection trust port ge.1.6 disable
set arpinspection limit port ge.1.6 rate 15 burst interval 1
set arpinspection trust port ge.1.7 disable
set arpinspection limit port ge.1.7 rate 15 burst interval 1
set arpinspection trust port ge.1.8 disable
set arpinspection limit port ge.1.8 rate 15 burst interval 1
set arpinspection trust port ge.1.9 disable
set arpinspection limit port ge.1.9 rate 15 burst interval 1
set arpinspection trust port ge.1.10 disable
set arpinspection limit port ge.1.10 rate 15 burst interval 1
set arpinspection trust port ge.1.11 disable
set arpinspection limit port ge.1.11 rate 15 burst interval 1
set arpinspection trust port ge.1.12 disable
set arpinspection limit port ge.1.12 rate 15 burst interval 1
set arpinspection trust port ge.1.13 disable
set arpinspection limit port ge.1.13 rate 15 burst interval 1
set arpinspection trust port ge.1.14 disable
set arpinspection limit port ge.1.14 rate 15 burst interval 1
set arpinspection trust port ge.1.15 disable
set arpinspection limit port ge.1.15 rate 15 burst interval 1
set arpinspection trust port ge.1.16 disable
set arpinspection limit port ge.1.16 rate 15 burst interval 1
set arpinspection trust port ge.1.17 disable
set arpinspection limit port ge.1.17 rate 15 burst interval 1
set arpinspection trust port ge.1.18 disable
set arpinspection limit port ge.1.18 rate 15 burst interval 1
set arpinspection trust port ge.1.19 disable
set arpinspection limit port ge.1.19 rate 15 burst interval 1
set arpinspection trust port ge.1.20 disable
set arpinspection limit port ge.1.20 rate 15 burst interval 1
set arpinspection trust port ge.1.21 disable
set arpinspection limit port ge.1.21 rate 15 burst interval 1
set arpinspection trust port ge.1.22 disable
set arpinspection limit port ge.1.22 rate 15 burst interval 1
set arpinspection trust port ge.1.23 disable
set arpinspection limit port ge.1.23 rate 15 burst interval 1
set arpinspection trust port ge.1.24 disable
set arpinspection limit port ge.1.24 rate 15 burst interval 1
set arpinspection trust port lag.0.1 disable
set arpinspection limit port lag.0.1 rate 15 burst interval 1
set arpinspection trust port lag.0.2 disable
set arpinspection limit port lag.0.2 rate 15 burst interval 1
set arpinspection trust port lag.0.3 disable
set arpinspection limit port lag.0.3 rate 15 burst interval 1
set arpinspection trust port lag.0.4 disable
set arpinspection limit port lag.0.4 rate 15 burst interval 1
set arpinspection trust port lag.0.5 disable
set arpinspection limit port lag.0.5 rate 15 burst interval 1
set arpinspection trust port lag.0.6 disable
set arpinspection limit port lag.0.6 rate 15 burst interval 1
#authentication
set authentication login any
#banner
#cdp
set cdp hold-time 180
set cdp interval 60
set cdp auth 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
set cdp state auto
set cdp state auto-enable ge.1.1
set cdp state auto-enable ge.1.2
set cdp state auto-enable ge.1.3
set cdp state auto-enable ge.1.4
set cdp state auto-enable ge.1.5
set cdp state auto-enable ge.1.6
set cdp state auto-enable ge.1.7
set cdp state auto-enable ge.1.8
set cdp state auto-enable ge.1.9
set cdp state auto-enable ge.1.10
set cdp state auto-enable ge.1.11
set cdp state auto-enable ge.1.12
set cdp state auto-enable ge.1.13
set cdp state auto-enable ge.1.14
set cdp state auto-enable ge.1.15
set cdp state auto-enable ge.1.16
set cdp state auto-enable ge.1.17
set cdp state auto-enable ge.1.18
set cdp state auto-enable ge.1.19
set cdp state auto-enable ge.1.20
set cdp state auto-enable ge.1.21
set cdp state auto-enable ge.1.22
set cdp state auto-enable ge.1.23
set cdp state auto-enable ge.1.24
#ciscodp
set ciscodp holdtime 180
set ciscodp time 60
set ciscodp status auto
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.1
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.2
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.3
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.4
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.5
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.6
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.7
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.8
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.9
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.10
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.11
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.12
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.13
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.14
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.15
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.16
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.17
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.18
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.19
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.20
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.21
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.22
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.23
set ciscodp port status enable vvid none trusted yes cos 0 ge.1.24
#console
set console baud 9600
#diffserv
set diffserv adminmode enable
#dhcps
set dhcp disable
set dhcp ping packets 2
set dhcp conflict logging
set dhcp bootp disable
#dhcpsnooping
set dhcpsnooping disable
set dhcpsnooping database write-delay 300
set dhcpsnooping verify mac-address enable
set dhcpsnooping trust port ge.1.1 disable
set dhcpsnooping log-invalid port ge.1.1 disable
set dhcpsnooping limit ge.1.1 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.2 disable
set dhcpsnooping log-invalid port ge.1.2 disable
set dhcpsnooping limit ge.1.2 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.3 disable
set dhcpsnooping log-invalid port ge.1.3 disable
set dhcpsnooping limit ge.1.3 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.4 disable
set dhcpsnooping log-invalid port ge.1.4 disable
set dhcpsnooping limit ge.1.4 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.5 disable
set dhcpsnooping log-invalid port ge.1.5 disable
set dhcpsnooping limit ge.1.5 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.6 disable
set dhcpsnooping log-invalid port ge.1.6 disable
set dhcpsnooping limit ge.1.6 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.7 disable
set dhcpsnooping log-invalid port ge.1.7 disable
set dhcpsnooping limit ge.1.7 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.8 disable
set dhcpsnooping log-invalid port ge.1.8 disable
set dhcpsnooping limit ge.1.8 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.9 disable
set dhcpsnooping log-invalid port ge.1.9 disable
set dhcpsnooping limit ge.1.9 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.10 disable
set dhcpsnooping log-invalid port ge.1.10 disable
set dhcpsnooping limit ge.1.10 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.11 disable
set dhcpsnooping log-invalid port ge.1.11 disable
set dhcpsnooping limit ge.1.11 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.12 disable
set dhcpsnooping log-invalid port ge.1.12 disable
set dhcpsnooping limit ge.1.12 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.13 disable
set dhcpsnooping log-invalid port ge.1.13 disable
set dhcpsnooping limit ge.1.13 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.14 disable
set dhcpsnooping log-invalid port ge.1.14 disable
set dhcpsnooping limit ge.1.14 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.15 disable
set dhcpsnooping log-invalid port ge.1.15 disable
set dhcpsnooping limit ge.1.15 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.16 disable
set dhcpsnooping log-invalid port ge.1.16 disable
set dhcpsnooping limit ge.1.16 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.17 disable
set dhcpsnooping log-invalid port ge.1.17 disable
set dhcpsnooping limit ge.1.17 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.18 disable
set dhcpsnooping log-invalid port ge.1.18 disable
set dhcpsnooping limit ge.1.18 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.19 disable
set dhcpsnooping log-invalid port ge.1.19 disable
set dhcpsnooping limit ge.1.19 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.20 disable
set dhcpsnooping log-invalid port ge.1.20 disable
set dhcpsnooping limit ge.1.20 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.21 disable
set dhcpsnooping log-invalid port ge.1.21 disable
set dhcpsnooping limit ge.1.21 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.22 disable
set dhcpsnooping log-invalid port ge.1.22 disable
set dhcpsnooping limit ge.1.22 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.23 disable
set dhcpsnooping log-invalid port ge.1.23 disable
set dhcpsnooping limit ge.1.23 rate 15 burst interval 1
set dhcpsnooping trust port ge.1.24 disable
set dhcpsnooping log-invalid port ge.1.24 disable
set dhcpsnooping limit ge.1.24 rate 15 burst interval 1
set dhcpsnooping trust port lag.0.1 disable
set dhcpsnooping log-invalid port lag.0.1 disable
set dhcpsnooping limit lag.0.1 rate 15 burst interval 1
set dhcpsnooping trust port lag.0.2 disable
set dhcpsnooping log-invalid port lag.0.2 disable
set dhcpsnooping limit lag.0.2 rate 15 burst interval 1
set dhcpsnooping trust port lag.0.3 disable
set dhcpsnooping log-invalid port lag.0.3 disable
set dhcpsnooping limit lag.0.3 rate 15 burst interval 1
set dhcpsnooping trust port lag.0.4 disable
set dhcpsnooping log-invalid port lag.0.4 disable
set dhcpsnooping limit lag.0.4 rate 15 burst interval 1
set dhcpsnooping trust port lag.0.5 disable
set dhcpsnooping log-invalid port lag.0.5 disable
set dhcpsnooping limit lag.0.5 rate 15 burst interval 1
set dhcpsnooping trust port lag.0.6 disable
set dhcpsnooping log-invalid port lag.0.6 disable
set dhcpsnooping limit lag.0.6 rate 15 burst interval 1
#eapol
set dot1x disable
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.1
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.2
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.3
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.4
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.5
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.6
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.7
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.8
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.9
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.10
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.11
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.12
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.13
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.14
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.15
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.16
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.17
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.18
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.19
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.20
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.21
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.22
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.23
set dot1x auth-config maxreq 2 quietperiod 60 reauthenabled false reauthperiod 3600 servertimeout 30 supptimeout 30 txperiod 30 ge.1.24
set dot1x port reauth false ge.1.1
set dot1x port reauth false ge.1.2
set dot1x port reauth false ge.1.3
set dot1x port reauth false ge.1.4
set dot1x port reauth false ge.1.5
set dot1x port reauth false ge.1.6
set dot1x port reauth false ge.1.7
set dot1x port reauth false ge.1.8
set dot1x port reauth false ge.1.9
set dot1x port reauth false ge.1.10
set dot1x port reauth false ge.1.11
set dot1x port reauth false ge.1.12
set dot1x port reauth false ge.1.13
set dot1x port reauth false ge.1.14
set dot1x port reauth false ge.1.15
set dot1x port reauth false ge.1.16
set dot1x port reauth false ge.1.17
set dot1x port reauth false ge.1.18
set dot1x port reauth false ge.1.19
set dot1x port reauth false ge.1.20
set dot1x port reauth false ge.1.21
set dot1x port reauth false ge.1.22
set dot1x port reauth false ge.1.23
set dot1x port reauth false ge.1.24
set dot1x port init false ge.1.1
set dot1x port init false ge.1.2
set dot1x port init false ge.1.3
set dot1x port init false ge.1.4
set dot1x port init false ge.1.5
set dot1x port init false ge.1.6
set dot1x port init false ge.1.7
set dot1x port init false ge.1.8
set dot1x port init false ge.1.9
set dot1x port init false ge.1.10
set dot1x port init false ge.1.11
set dot1x port init false ge.1.12
set dot1x port init false ge.1.13
set dot1x port init false ge.1.14
set dot1x port init false ge.1.15
set dot1x port init false ge.1.16
set dot1x port init false ge.1.17
set dot1x port init false ge.1.18
set dot1x port init false ge.1.19
set dot1x port init false ge.1.20
set dot1x port init false ge.1.21
set dot1x port init false ge.1.22
set dot1x port init false ge.1.23
set dot1x port init false ge.1.24
set eapol disable
set eapol auth-mode auto ge.1.1
set eapol auth-mode auto ge.1.2
set eapol auth-mode auto ge.1.3
set eapol auth-mode auto ge.1.4
set eapol auth-mode auto ge.1.5
set eapol auth-mode auto ge.1.6
set eapol auth-mode auto ge.1.7
set eapol auth-mode auto ge.1.8
set eapol auth-mode auto ge.1.9
set eapol auth-mode auto ge.1.10
set eapol auth-mode auto ge.1.11
set eapol auth-mode auto ge.1.12
set eapol auth-mode auto ge.1.13
set eapol auth-mode auto ge.1.14
set eapol auth-mode auto ge.1.15
set eapol auth-mode auto ge.1.16
set eapol auth-mode auto ge.1.17
set eapol auth-mode auto ge.1.18
set eapol auth-mode auto ge.1.19
set eapol auth-mode auto ge.1.20
set eapol auth-mode auto ge.1.21
set eapol auth-mode auto ge.1.22
set eapol auth-mode auto ge.1.23
set eapol auth-mode auto ge.1.24
#flowcontrol
set flowcontrol enable
#garp
set garp timer join 20 leave 60 leaveall 1000 ge.1.1
set garp timer join 20 leave 60 leaveall 1000 ge.1.2
set garp timer join 20 leave 60 leaveall 1000 ge.1.3
set garp timer join 20 leave 60 leaveall 1000 ge.1.4
set garp timer join 20 leave 60 leaveall 1000 ge.1.5
set garp timer join 20 leave 60 leaveall 1000 ge.1.6
set garp timer join 20 leave 60 leaveall 1000 ge.1.7
set garp timer join 20 leave 60 leaveall 1000 ge.1.8
set garp timer join 20 leave 60 leaveall 1000 ge.1.9
set garp timer join 20 leave 60 leaveall 1000 ge.1.10
set garp timer join 20 leave 60 leaveall 1000 ge.1.11
set garp timer join 20 leave 60 leaveall 1000 ge.1.12
set garp timer join 20 leave 60 leaveall 1000 ge.1.13
set garp timer join 20 leave 60 leaveall 1000 ge.1.14
set garp timer join 20 leave 60 leaveall 1000 ge.1.15
set garp timer join 20 leave 60 leaveall 1000 ge.1.16
set garp timer join 20 leave 60 leaveall 1000 ge.1.17
set garp timer join 20 leave 60 leaveall 1000 ge.1.18
set garp timer join 20 leave 60 leaveall 1000 ge.1.19
set garp timer join 20 leave 60 leaveall 1000 ge.1.20
set garp timer join 20 leave 60 leaveall 1000 ge.1.21
set garp timer join 20 leave 60 leaveall 1000 ge.1.22
set garp timer join 20 leave 60 leaveall 1000 ge.1.23
set garp timer join 20 leave 60 leaveall 1000 ge.1.24
set garp timer join 20 leave 60 leaveall 1000 lag.0.1
set garp timer join 20 leave 60 leaveall 1000 lag.0.2
set garp timer join 20 leave 60 leaveall 1000 lag.0.3
set garp timer join 20 leave 60 leaveall 1000 lag.0.4
set garp timer join 20 leave 60 leaveall 1000 lag.0.5
set garp timer join 20 leave 60 leaveall 1000 lag.0.6
#gvrp
set gvrp enable
set gvrp disable ge.1.1
set gvrp disable ge.1.2
set gvrp disable ge.1.3
set gvrp disable ge.1.4
set gvrp disable ge.1.5
set gvrp disable ge.1.6
set gvrp disable ge.1.7
set gvrp disable ge.1.8
set gvrp disable ge.1.9
set gvrp disable ge.1.10
set gvrp disable ge.1.11
set gvrp disable ge.1.12
set gvrp disable ge.1.13
set gvrp disable ge.1.14
set gvrp disable ge.1.15
set gvrp disable ge.1.16
set gvrp disable ge.1.17
set gvrp disable ge.1.18
set gvrp disable ge.1.19
set gvrp disable ge.1.20
set gvrp disable ge.1.21
set gvrp disable ge.1.22
set gvrp disable ge.1.23
set gvrp disable ge.1.24
set gvrp disable lag.0.1
set gvrp disable lag.0.2
set gvrp disable lag.0.3
set gvrp disable lag.0.4
set gvrp disable lag.0.5
set gvrp disable lag.0.6
#history
set history 20 default
#igmp
set igmpsnooping adminmode disable
set igmpsnooping groupmembershipinterval 260
set igmpsnooping maxresponse 100
set igmpsnooping mcrtexpiretime 0
#inlinepower
set inlinepower trap enable 1
set inlinepower threshold 80 1
set inlinepower detectionmode auto
#ipv6
set ipv6 disable
#lacp
set lacp aadminkey lag.0.1 32768
set lacp aadminkey lag.0.2 32768
set lacp aadminkey lag.0.3 32768
set lacp aadminkey lag.0.4 32768
set lacp aadminkey lag.0.5 32768
set lacp aadminkey lag.0.6 32768
set lacp asyspri 32768
set lacp enable
set lacp singleportlag disable
#length
set length 0
#lldp
set lldp tx-interval 30
set lldp hold-multipler 4
set lldp trap-interval 5
set lldp med-fast 3
set lldp port status both ge.1.1
set lldp port status both ge.1.2
set lldp port status both ge.1.3
set lldp port status both ge.1.4
set lldp port status both ge.1.5
set lldp port status both ge.1.6
set lldp port status both ge.1.7
set lldp port status both ge.1.8
set lldp port status both ge.1.9
set lldp port status both ge.1.10
set lldp port status both ge.1.11
set lldp port status both ge.1.12
set lldp port status both ge.1.13
set lldp port status both ge.1.14
set lldp port status both ge.1.15
set lldp port status both ge.1.16
set lldp port status both ge.1.17
set lldp port status both ge.1.18
set lldp port status both ge.1.19
set lldp port status both ge.1.20
set lldp port status both ge.1.21
set lldp port status both ge.1.22
set lldp port status both ge.1.23
set lldp port status both ge.1.24
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.1
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.1
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.1
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.1
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.1
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.1
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.1
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.1
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.2
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.2
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.2
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.2
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.2
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.2
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.2
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.2
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.3
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.3
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.3
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.3
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.3
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.3
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.3
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.3
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.4
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.4
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.4
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.4
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.4
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.4
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.4
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.4
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.5
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.5
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.5
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.5
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.5
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.5
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.5
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.5
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.6
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.6
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.6
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.6
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.6
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.6
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.6
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.6
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.7
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.7
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.7
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.7
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.7
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.7
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.7
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.7
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.8
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.8
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.8
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.8
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.8
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.8
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.8
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.8
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.9
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.9
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.9
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.9
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.9
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.9
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.9
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.9
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.10
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.10
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.10
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.10
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.10
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.10
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.10
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.10
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.11
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.11
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.11
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.11
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.11
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.11
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.11
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.11
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.12
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.12
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.12
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.12
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.12
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.12
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.12
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.12
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.13
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.13
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.13
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.13
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.13
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.13
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.13
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.13
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.14
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.14
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.14
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.14
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.14
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.14
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.14
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.14
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.15
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.15
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.15
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.15
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.15
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.15
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.15
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.15
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.16
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.16
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.16
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.16
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.16
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.16
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.16
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.16
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.17
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.17
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.17
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.17
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.17
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.17
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.17
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.17
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.18
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.18
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.18
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.18
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.18
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.18
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.18
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.18
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.19
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.19
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.19
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.19
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.19
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.19
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.19
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.19
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.20
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.20
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.20
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.20
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.20
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.20
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.20
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.20
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.21
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.21
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.21
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.21
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.21
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.21
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.21
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.21
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.22
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.22
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.22
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.22
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.22
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.22
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.22
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.22
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.23
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.23
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.23
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.23
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.23
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.23
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.23
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.23
set lldp port network-policy voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.24
set lldp port network-policy voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.24
set lldp port network-policy guest-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.24
set lldp port network-policy guest-voice-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.24
set lldp port network-policy softphone-voice state disable tag untagged vid 1 cos 0 dscp 0 ge.1.24
set lldp port network-policy video-conferencing state disable tag untagged vid 1 cos 0 dscp 0 ge.1.24
set lldp port network-policy streaming-video state disable tag untagged vid 1 cos 0 dscp 0 ge.1.24
set lldp port network-policy video-signaling state disable tag untagged vid 1 cos 0 dscp 0 ge.1.24
#linkflap
set linkflap globalstate disable
set linkflap portstate disable ge.1.1
set linkflap threshold ge.1.1 10
set linkflap interval ge.1.1 5
set linkflap downtime ge.1.1 300
set linkflap portstate disable ge.1.2
set linkflap threshold ge.1.2 10
set linkflap interval ge.1.2 5
set linkflap downtime ge.1.2 300
set linkflap portstate disable ge.1.3
set linkflap threshold ge.1.3 10
set linkflap interval ge.1.3 5
set linkflap downtime ge.1.3 300
set linkflap portstate disable ge.1.4
set linkflap threshold ge.1.4 10
set linkflap interval ge.1.4 5
set linkflap downtime ge.1.4 300
set linkflap portstate disable ge.1.5
set linkflap threshold ge.1.5 10
set linkflap interval ge.1.5 5
set linkflap downtime ge.1.5 300
set linkflap portstate disable ge.1.6
set linkflap threshold ge.1.6 10
set linkflap interval ge.1.6 5
set linkflap downtime ge.1.6 300
set linkflap portstate disable ge.1.7
set linkflap threshold ge.1.7 10
set linkflap interval ge.1.7 5
set linkflap downtime ge.1.7 300
set linkflap portstate disable ge.1.8
set linkflap threshold ge.1.8 10
set linkflap
Photo of Miguel Bahi
Miguel Bahi
  • 100 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Adilson Gal
Adilson Gal, Employee
  • 1,408 Points 1k badge 2x thumb
It looks like you've got a bad hardware. Access the url https://extranet.extremenetworks.com/mysupport/ocm/pages/rma.aspx to generate RMA for the faulty unit.
