Port utilization in % on uplinks using Netsight
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
I want to monitor the utilization in % on the uplinks of XOS switches. How do I do this?
In the console you can select the flexview "port utilization in percent", which is the one I need. But how do I add the ports I want to see and how do I display them in OneView?
Photo of Ramon Voorn
Ramon Voorn
  • 150 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Thomas, Frank
Thomas, Frank, Employee
  • 1,902 Points 1k badge 2x thumb
Hi,Have you tried custom reports, under reports?
Select a switch, collect interface statistics
Alternatively you can collect interface stats from console [May have to depending of version of Netsight running 6.1 vs 6.2 vs 6.3]
After 10-15 minutes, we will have collected interface stats to start graphing.
In Oneview
Under Custom Reports Select interfaces  and choose what you want to graph %utils
Not sure if this was added in 6.2 or 6.3
Save it report designer as an option
In Administration tab go to Report Designer
Pick the custom report option we created, additional elements can be created and added together as well for a single report.
Save then under reports we can then view anything we created
(Edited)
Ramon Voorn
Great! This is exactly what I was looking for! I will check it out later but I guess this is the solution.
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Welcome to the Hub Ramon.  That's how this community rolls!
You'll find lots of knowledge sharing, purple passion and speedy responses.
Appreciate you joining us.
Definitely let us know if you have any issues
