Port will not egress any VLAN
  • Question
  • Updated 2 years ago
  • Answered
I am trying to assign a specific port to a specific VLAN. However, after issuing the commands the egress of the port doesn't become modified.
I have an S series chassis.
Here are the commands I am using:
set vlan egress 90 ge.3.2 untagged
set port vlan ge.3.2 90 modify-egress
I then used the following command to verify my work:
show port vlan ge.3.2
ge.3.2 is set to 90
show port egress ge.3.2
output comes up with nothing.
show vlan
VLAN     : 1           Status     : Enabled
FID      : 1           Name       : Default VLAN
VLAN Type: Permanent  Last Change: 2016-11-21 12:11:30
 Egress Ports:
host.0.1;ge.1.1;ge.3.9-13,15,29,31,33-34,36,38-40,47;tg.3.101,201;ge.4.1-2,14,32;tg.4.101,201
 Forbidden Egress Ports:
None.
 Untagged Ports:
ge.1.1;ge.3.9-13,15,29,31,33-34,36,38-40,47;ge.4.1-2,14,32;tg.4.101
VLAN     : 11          Status     : Enabled
FID      : 11          Name       : (none)
VLAN Type: Permanent  Last Change: 2016-10-01 21:05:46
 Egress Ports:
None.
None.
 Untagged Ports:
None.
VLAN     : 30          Status     : Enabled
FID      : 30          Name       : ISCSI
VLAN Type: Permanent  Last Change: 2016-09-23 19:16:24
 Egress Ports:
tg.1.101-102,203;tg.2.102,203;tg.3.102,203-204;tg.4.102,203-204
None.
 Untagged Ports:
VLAN     : 75          Status     : Enabled
FID      : 75          Name       : (none)
VLAN Type: Permanent  Last Change: 2016-10-08 21:41:53
 Egress Ports:
host.0.1;tg.3.101,201;tg.4.201
None.
 Untagged Ports:
None.
VLAN     : 80          Status     : Enabled
FID      : 80          Name       : EdgePorts
VLAN Type: Permanent  Last Change: 2016-11-04 18:17:33
 Egress Ports:
ge.4.2
None.
 Untagged Ports:
None.
VLAN     : 90          Status     : Enabled
FID      : 90          Name       : (none)
VLAN Type: Permanent  Last Change: 2016-11-21 12:05:47
 Egress Ports:
ge.1.2;ge.2.24;ge.3.24;ge.4.24
None.
 Untagged Ports:
ge.1.2
VLAN     : 95          Status     : Enabled
FID      : 95          Name       : (none)
VLAN Type: Permanent  Last Change: 2016-10-08 21:42:42
 Egress Ports:
None.
 Untagged Ports:
None.
VLAN     : 111         Status     : Enabled
FID      : 111         Name       : (none)
VLAN Type: Permanent  Last Change: 2016-11-04 18:18:39
 Egress Ports:
host.0.1;ge.1.1;ge.4.2
None.
 Untagged Ports:
None.
VLAN     : 133         Status     : Enabled
FID      : 133         Name       : (none)
VLAN Type: Permanent  Last Change: 2016-06-16 18:27:51
 Egress Ports:
host.0.1;ge.4.1
None.
 Untagged Ports:
None.
Is there something I am doing wrong?
Photo of Eddie Brown
Eddie Brown
  • 192 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,880 Points 20k badge 2x thumb
Just use "set port vlan ge.3.2 90 modify-egress" as that will already set the egress.
You don't need the other command for a untagged port.
So please type it in again and check.
To check use the command "show vlan static 90".
This will also show port/VLAN if the port is down/disconnected.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,220 Points 10k badge 2x thumb
The "show port egress" shows active VLANs only. If the port is down, no VLAN is displayed, because nothing is active on the port. The same is true for "show vlan".
The command "show vlan static" shows the VLAN configuration, as does the "show vlan portinfo" command.
Photo of Alex Morrissey
Alex Morrissey, Employee
  • 862 Points 500 badge 2x thumb
Another consideration when using "show vlan" and "show port egress" is the vlan egress will only be displayed if the port is forwarding.  So if the port is blocked by spanning tree or some other mechanism then the vlan egress will not be displayed.  In those cases the commands "show vlan static" and "show vlan portinfo" commands Erik provided would be the prefered method.
-Alex
