Port aggregation not working properly on Black Diamond 8810 switches
  • Problem
  • Updated 4 years ago
  • Solved
We are doing Port Aggregation between two Black Diamonds ( 4 Ports ) , but we found that only one ports is taking max traffic and even dropping packets in peak hours . Rest of the ports in LAG barely taking some traffic .
enable sharing 9:23 grouping 9:23-24, 9:47-48 algorithm address-based L2 lacp
Photo of Ashu Chauhan
Ashu Chauhan
  • 70 Points
  • Frustrated
Posted 4 years ago
Photo of Daniel Flouret
Daniel Flouret, Employee
  • 7,470 Points 5k badge 2x thumb
Official Response
The problem is probably be related to the algorithm you chose for load-sharing.
If you have a server that is accessed from other vlans or the internet, all traffic to/from it will be exchanged between the server mac and the default gateway mac, even though it belongs to multiple sessions and users, and will be sent through one and only one link in the LAG.
If you change it to L3_L4 (enable sharing 9:23 grouping 9:23-24, 9:47-48 algorithm address-based L3_L4 lacp), traffic will be balanced based on the source and destination IP and port and you'll see a better load balancing among the multiple links in the LAG.
Regards, Daniel
