Port Default Policy Role between Console and Policy Mngr is out-of-sync
  • Question
  • Updated 5 years ago
  • Answered
Why would Console and Policy Mngr differ when viewing the default port policy role that is being applied.  Policy Mngr is showing in one case 20 ports with a specific role and Console only shows the role on 10 of those ports
Photo of Walt Witkowski
Walt Witkowski
  • 436 Points 250 badge 2x thumb
Posted 5 years ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 10,286 Points 10k badge 2x thumb
are all those ports the same king (physical). In PM there is option to show also virtual ports = LAG.
It should read the same OID from the mib, the data should be the same. Can you share the screenshot?
Z.
Walt Witkowski
Enterasys has confirmed that they are aware of this issue. I am running Netsight 5.1 and Netsight ver.6.1 is in the works with a fix. Screen shots are available in the case 01021283. Clarification... When viewing Netsight Console the "BasicPolicy" tab all the ports set to have a specific default role do not show the role, under the "Default Role" column. If I SSH to the switch (C3) and do a "show config policy" the "set policy port xx.x x is there for every port intended. The Netsight Policy Mngr. also shows all the intended ports for the role when I select a role and under the "ports" tab do a retrieve operation.
