Port flap on LACP load sharing group causes permanent network loop
  • Problem
  • Updated 4 years ago
Had a neat issue that killed our network the other day.  Tracked it down to a flaky port on a single switch that was connected to a stack with LACP.  I was able to reproduce the problem.
Take a stack and LACP load share one port from each stack member to 2 ports on another switch, send some multicast traffic across it (VRRP or ELRP is enough), then unplug and plug in one of the ports several times.
Eventually, the LACP link will stop forwarding within the confines of the algorith and it turns the ports into a big L2 loop.  Doesnt seem to happen with static sharing, just LACP.  Reproduced on x450e-48p, but appears to happen on x460s as well, 15.3.3.5p1-2
Photo of Tim DeNike
Tim DeNike
  • 110 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Please call the TAC and report the bug.
Photo of Tim DeNike
Tim DeNike
Case open for 3 weeks.
Sumit Tokle, Alum
Can I have case number?
