Port Sharing issue
  • Question
  • Updated 5 years ago
Create Date: Apr 11 2012 9:44PM
Hello Guys,
I have BD8810 (XOS ver: 12.3.3.6) switch on which servers are connected , we have few serves with multiple LAN ports with teaming enabled and in load balance mode.
i did port sharing for coupling 2 switch port for getting 2GBPS through put ,command i used is ' enable sharing 1:41 grouping 1:41-42 algorithm address-based L2'
but while checking traffic on server LAN cards .. on both lan cards i saw Sent packets but received packets are seen on only 1 lan card of server
both ports connected on same switch
Pls let me know if i have to do any twicking at switch side configuration ?
Thanks
Deepak
(from Deepak_Patkar)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Apr 11 2012 11:58PM
<p> Is the server end also using address based L2? Make sure that's the case</p>
<p>verify the output of "show port utilization". see the Tx and RX packets on both ports.</p>
<p>Also "show vlan <Vlan name>" for the vlan that contains these ports and verify if one of the ports is blocked or not. It will show (g) for sharing and (gb) for blocked port.</p>
(from Arpit_Bhatt)
