Possible to stack x480-48t with a x620-16X?
  • Question
  • Updated 1 year ago
  • Answered
I have an x480 that I want to add multiple 10G ports to. Is it possible to stack this with a x620-16X?
If yes, what modules would I need to add-on/buy for both switches?
Photo of Kaon Thana
Kaon Thana
  • 256 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,442 Points 5k badge 2x thumb
Bad luck here.
You need the same firmware on both units. But X620 starts on 21.x and X480 stays at 16.x.
You can still use MLAG and EAPS, but each device will have own IP address and config.
Z.
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hello Kaon,
It is not possible due to the minimum and maximum code supported for those switches. The x480 can only be upgraded to 16.2 and the minimum version allowed on the x620 is 21.1.
Photo of Kaon Thana
Kaon Thana
Do I have any options of buying a switch with multiple 10G ports to stack with the x480?
I know the x480 has the 4x10G module but I want more than 4 ports.
Photo of Kaon Thana
Kaon Thana
How about stacking the x480 with a X650-24x? Could that work?
Hello Kaon,
Those two switches can run the same version of code. I would recommend looking at our stacking tool for different methods on stacking and what switches are compatible with what:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Where-Can-I-Find-the-EXOS-Stacking-Tool
As far as the minimum and maximum software you can utilize the link below:
http://www.extremenetworks.com/extreme-hardwaresoftware-compatibility-recommendation-matrices/summit...
Hope this helps!
Photo of Kaon Thana
Kaon Thana
The x650 is not listed as an option on this tool.
Hello Kaon,
The stacking tool is relatively new. The x650 is a EOS product and I am assuming it wasn't added because of this.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,492 Points 10k badge 2x thumb
You can use a x670V to stack with a x480, using the 40G VIMs, for example. But you'd limit the scalability of the x480 to the x670V.
