Post Summit switch upgrade to 15.5 session stuck on login page
  • Problem
  • Updated 3 years ago
  • Solved
admin@KASR01> telnet routing-instance OM_CN 10.82.48.196
Trying 10.82.48.196...
Connected to 10.82.48.196.
Escape character is '^]'.
telnet session telnet1 on /dev/ptyb1
login: narender
password:
not goin post login via oss it stuck on login page
even direct login is working fine...
please confirm if faced such problem..
Photo of Narender kumar
Narender kumar
  • 430 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,058 Points 5k badge 2x thumb
Did you got a chance to telnet in to the switch with a different tool say Putty? if not can you try and see if it is getting struck as well?
If you face the issue in other tool as well then i would suggest you to open up a GTAC case for the issue with the below details.
"show tech"
"show log messages nvram"
If it is an option try to have a PC directly connected to the switch port and try to telnet and share the results. This would help to isolate if the issue is in the pathway or not.
In addition please do share the previous software version details.
Narender kumar
direct telnet from P2P link on port is working fine ... even after degrade we are able to telenet node...
now treid again , it stuck into bootrom mode...
Narender kumar
Current version is IMG: 12.6.1.3 & going with summitX-15.5.1.6.xos
NWI-E_B.1 # show log messages nvram
12/11/2015 12:12:48.18 Shutting down all processes
12/11/2015 12:12:47.93 Rebooting with reason User requested switch reboot
12/11/2015 12:05:50.43 Upgrade status Start upgrade timer
12/11/2015 11:56:23.09 Upgrade failed, script: download failed
12/11/2015 11:55:25.89 Upgrade failed, script: download failed
12/11/2015 11:55:20.42 Upgrade failed, script: download failed
12/11/2015 11:55:11.07 Upgrade failed, script: download failed
12/11/2015 11:41:58.74 Error while loading "vrrp_cm_vr_enable": Failed to enable VR for vlan SR_OM, vrid 60:
                        VR must have at least 1 virtual IP address!
12/11/2015 11:41:58.70 Error while loading "vrrp_cm_vr_enable": Failed to enable VR for vlan BSC_Inner, vrid 80:
12/11/2015 11:41:58.69 Error while loading "vrrp_cm_viptable": Virtual IP address must be specified!
12/11/2015 11:39:52.93 Shutting down all processes
12/11/2015 11:39:52.90 Switch FAILED (1) Process Failure
12/11/2015 11:39:52.43 Node State[4] = FAIL (Process Failure)
12/11/2015 11:39:52.43 Process cli Failed
12/11/2015 11:39:52.42 Rebooting with reason
12/11/2015 11:39:52.18 Configuration database locked
12/11/2015 11:39:52.16 Connection lost with process cli
12/11/2015 11:39:41.29 CPU utilization monitor: process cli consumes 95 %% CPU
12/11/2015 11:39:36.29 CPU utilization monitor: process cli consumes 96 %% CPU
12/11/2015 11:39:29.60 2aae719c  00000000 nop
12/11/2015 11:39:29.60 2aae7198  1080fffc beq    a0,zero,0x2aae718c
12/11/2015 11:39:29.60 2aae7194  e2040000 sc     a0,0(s0)
12/11/2015 11:39:29.60 2aae7190  00402021 addu   a0,v0,zero
12/11/2015 11:39:29.60 2aae718c  c2030000 ll     v1,0(s0)
12/11/2015 11:39:29.60 2aae7188 <24020002>addiu  v0,zero,2
12/11/2015 11:39:29.60 2aae7184  0000000c syscall 0
12/11/2015 11:39:29.60 2aae7180  2402108e addiu  v0,zero,4238
12/11/2015 11:39:29.60 2aae717c  00003821 addu   a3,zero,zero
12/11/2015 11:39:29.60 Code:
12/11/2015 11:39:29.60 Process cliMaster signal 6 code
12/11/2015 11:39:29.19 Process cli ID 1418 killed
12/11/2015 11:39:29.19 Because the main (715967328) thread of process 1418, has not responded within 41 periods of 6 seconds, the process will be terminated.
12/11/2015 11:23:23.86 Error while loading "vrrp_cm_vr_enable": Failed to enable VR for vlan SR_OM, vrid 60:
12/11/2015 11:23:23.84 Error while loading "vrrp_cm_vr_enable": Failed to enable VR for vlan BSC_Inner, vrid 80:
12/11/2015 11:23:23.82 Error while loading "vrrp_cm_viptable": Virtual IP address must be specified!
12/11/2015 11:21:07.00 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-00: 00 9C 00 01 FF FF FF FF 00 00 05 F2 56 6A B1 A3 '............Vj..'
                       DUMP-10: 00 00 03 BF 00 7D 00 00 00 FF 00 2C 00 00 00 21 '.....}.....,...!'
                       DUMP-20: 76 72 72 70 5F 61 64 76 65 72 74 2E 63 00 5F 45 'vrrp_advert.c._E'
                       DUMP-30: 4D 53 5F 56 52 52 50 5F 41 64 76 65 72 74 5F 49 'MS_VRRP_Advert_I'
                       DUMP-40: 67 6E 00 00 01 FF 00 0C 76 72 72 70 00 00 00 00 'gn......vrrp....'
                       DUMP-50: 06 00 00 10 42 53 43 5F 49 6E 6E 65 72 00 00 00 '....BSC_Inner...'
                       DUMP-60: 02 01 00 08 00 00 00 50 06 02 00 20 50 61 63 6B '.......P... Pack'
                       DUMP-70: 65 74 20 76 65 72 69 66 69 63 61 74 69 6F 6E 20 'et verification '
                       DUMP-80: 66 61 69 6C 65 64 00 00 08 09 00 14 00 09 00 01 'failed..........'
                       DUMP-90: 56 52 52 50 2E 41 64 76 65 72 74 00             'VRRP.Advert.    '
                       DUMP-60: 02 01 00 08 00 00 00 50 06 02 00 20 61 64 76 65 '.......P... adve'
                       DUMP-70: 72 74 20 69 6E 74 65 72 76 61 6C 20 6D 69 73 6D 'rt interval mism'
                       DUMP-80: 61 74 63 68 00 00 00 00 08 09 00 14 00 09 00 01 'atch............'
12/11/2015 11:21:06.90 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-00: 00 9C 00 01 FF FF FF FF 00 00 05 F2 56 6A B1 A2 '............Vj..'
                       DUMP-10: 00 0D BF 5F 00 7D 00 00 00 FF 00 2C 00 00 00 21 '..._.}.....,...!'
                       DUMP-80: 66 61 69 6C 65 64 00 00 08 74 00 14 00 09 00 01 'failed...t......'
                       DUMP-80: 61 74 63 68 00 00 00 00 08 6F 00 14 00 09 00 01 'atch.....o......'
12/11/2015 11:21:06.80 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-00: 00 98 00 01 FF FF FF FF 00 00 05 F2 56 6A B1 A2 '............Vj..'
                       DUMP-10: 00 0C 38 BF 00 7D 00 00 00 FF 00 2C 00 00 00 21 '..8..}.....,...!'
                       DUMP-50: 06 00 00 0C 53 52 5F 4F 4D 00 00 00 02 01 00 08 '....SR_OM.......'
                       DUMP-60: 00 00 00 3C 06 02 00 20 61 64 76 65 72 74 20 69 '...<... advert i'
                       DUMP-70: 6E 74 65 72 76 61 6C 20 6D 69 73 6D 61 74 63 68 'nterval mismatch'
                       DUMP-80: 00 00 00 00 08 61 00 14 00 09 00 01 56 52 52 50 '.....a......VRRP'
                       DUMP-90: 2E 41 64 76 65 72 74 00                         '.Advert.       '
                       DUMP-80: 66 61 69 6C 65 64 00 00 08 6F 00 14 00 09 00 01 'failed...o......'
                       DUMP-80: 61 74 63 68 00 00 00 00 08 69 00 14 00 09 00 01 'atch.....i......'
12/11/2015 11:21:06.70 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                           DUMP-10: 00 0A B2 1F 00 7D 00 00 00 FF 00 2C 00 00 00 21 '.....}.....,...!'
     12/11/2015 11:21:06.60 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-10: 00 09 2B 7F 00 7D 00 00 00 FF 00 2C 00 00 00 21 '..+..}.....,...!'
                       DUMP-80: 66 61 69 6C 65 64 00 00 08 69 00 14 00 09 00 01 'failed...i......'
12/11/2015 11:21:06.50 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-10: 00 07 A4 DF 00 7D 00 00 00 FF 00 2C 00 00 00 21 '.....}.....,...!'
12/11/2015 11:21:06.40 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-10: 00 06 1E 3F 00 7D 00 00 00 FF 00 2C 00 00 00 21 '...?.}.....,...!'
12/11/2015 11:21:06.31 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-10: 00 04 BE AF 00 7D 00 00 00 FF 00 2C 00 00 00 21 '.....}.....,...!'
12/11/2015 11:21:06.21 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-10: 00 03 38 0F 00 7D 00 00 00 FF 00 2C 00 00 00 21 '..8..}.....,...!'
12/11/2015 11:21:06.11 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-10: 00 01 B1 6F 00 7D 00 00 00 FF 00 2C 00 00 00 21 '...o.}.....,...!'
12/11/2015 11:21:06.01 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-10: 00 00 2A CF 00 7D 00 00 00 FF 00 2C 00 00 00 21 '..*..}.....,...!'
12/11/2015 11:21:05.91 NO MESSAGE DECODE; Missing component "VRRP.Advert" v9.1
                       DUMP-00: 00 98 00 01 FF FF FF FF 00 00 05 F2 56 6A B1 A1 '............Vj..'
                       DUMP-10: 00 0D E6 6F 00 7D 00 00 00 FF 00 2C 00 00 00 21 '...o.}.....,...!'
                       DUMP-00: 00 9C 00 01 FF FF FF FF 00 00 05 F2 56 6A B1 A1 '............Vj..'
Photo of Drew C.
Drew C., Community Manager
  • 40,206 Points 20k badge 2x thumb
Hi Narender, I would recommend that you contact GTAC for help resolving this issue.
Narender kumar
Case has been locked with GTAC , Waiting for onsite engineer to share show tech logs ...
