Power cables for SSA switches.
  • Question
  • Updated 3 years ago
  • Answered
Customer needs 15' power cables and the standard length is 6'. Having issue trying to determine length of power cables from the part number description. Have already looked at the power cord document and the price list, but no mention of lengths. Figured easiest way to do this is have customer purchase third party cables with specification listed.
Photo of Brian Onstott
Brian Onstott
  • 70 Points
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,594 Points 10k badge 2x thumb
Hi Brian,
Looking over the price list, I do not see any cables other than the 6' ones. I'll double check, but since you need 15' cables, third party may be the best option.
-Brandon
Photo of Drew C.
Drew C., Community Manager
  • 40,690 Points 20k badge 2x thumb
Hi Brian,
I believe Brandon is correct - we only sell the standard 6' power cables.  For anything "specialty" in our labs, I usually buy from stayonline.com or monoprice.com.  Between those two, you'll find everything you need.
