Power log messages
  • Question
  • Updated 2 years ago
  • Answered
Below is a part of the logs form Slot-3 of our 3 node stack.
Can anyone tell me what the error messages mean? I have the EMS catalog, but it only tells says that HAL.Card.Error is a serious error.
06/06/2016 08:07:36.84 Slot-3: Power usage monitoring not supported for PSU (Part name Internal Power Supply ) in slot 9
06/06/2016 08:07:29.65 Slot-3: Watchdog enabled
06/06/2016 08:07:28.76 Slot-3: poePlusInit: PSE initialization failed
06/06/2016 08:07:28.76 Slot-3: Failed to communicate with PSE.
06/06/2016 08:07:28.76 Slot-3: pse_uart_xfer: Did not receive valid response
06/06/2016 08:07:28.71 Slot-3: bcmPseReceiveMessageString: timed out
06/06/2016 08:07:25.03 Slot-3: Setting time to Mon Jun 6 13:07:25 2016
Thanks in advance!
-B
Photo of bw447
bw447
  • 966 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Ijaz Chughtai
Ijaz Chughtai, Employee
  • 220 Points 100 badge 2x thumb
Please see articles:
https://gtacknowledge.extremenetworks.com/articles/Solution/EXOS-switch-Erro-HAL-Card-Error-poePlusI...
https://gtacknowledge.extremenetworks.com/articles/Solution/Summit-PoE-failure-and-switch-pass-exten...
PoE on the switch in slot 3 seems to be failing and needs to be checked/verified/diagnosed with the steps listed in articles.
Please share more details about your switch - type of hardware / EXOS version if problem still persists. Most likely will need to open a GTAC case if switch fails diagnostics.
Thanks,
Ijaz
