Private VLAN routing issue
  • Problem
  • Updated 6 months ago
  • Solved
I've configured a private VLAN for  ports 1 and 2 so that they are isolated from one another. The configuration shown below is how I set it up, however, when I place a client on port 1 I can not ping the gateway.The client can ping the VLAN Mgmt99 IP: 10.10.99.6. Note port 48 is a trunk port to my core switch with the same Mgmt99 VLAN on it. I tried ipforwarding of mgmt99 vlan but that did not help.
create vlan "Mgmt99"
configure vlan Mgmt99 tag 99
create vlan "Mgmt99_pv_isol"
configure vlan Mgmt99_pv_isol tag 199
create private-vlan "Mgmt99_PV"
configure private-vlan Mgmt99_PV add network Mgmt99
configure private-vlan Mgmt99_PV add subscriber Mgmt99_pv_isol
configure vlan Mgmt99 add ports 48 tagged (Trunk Port)
configure vlan Mgmt99_pv_isol add ports 1-2 untagged
configure vlan Mgmt99 ipaddress 10.10.99.6 255.255.255.0
configure iproute add default 10.10.99.1
Thanks for any suggestions.
Photo of Andrew Schulz
Andrew Schulz
  • 432 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,168 Points 5k badge 2x thumb
Andrew,
Could you add the below config line and check.
 "configure vlan Mgmt99 add ports 1 private-vlan translated"
Andrew Schulz
I get the following error when I add that config.
Error: Can't add ports because they already exist in a Subscriber VLAN.
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Hi Andrew,
Please try adding the port 48 as a translated port.
configure Vlan mgmt99 add port 48 private-Vlan translated.
Let us know the results!
Hi Andrew,
Similar example is explained in the User guide: under the section, "Extending Network and Subscriber VLANs to Other Switches"
http://documentation.extremenetworks.com/exos/EXOS_21_1/VLAN/c_extending-network-and-subscriber-vlan...
If you would require any clarification, please feel free to let us know.
(Edited)
Andrew Schulz
When I add vlan mgmt99 port 48 to private-vlan translated I get the following notice. I said yes to it.
Adding an existing untagged member port of vlan Mgmt99 as tagged can cause STP configuration loss.
Do you really want to add these ports? (y/N) Yes
After making that change the client on port 1 can ping the gateway and is isolated as I wanted. Thanks for the help on this and thanks for pointing to the support document as well, that helped.
Photo of nola saint
nola saint
  • 490 Points 250 badge 2x thumb
Please explain how that change give you the desired result.
