Problem logging in to the Support Portal
  • Problem
  • Updated 3 years ago
Every time I try to log in to the Support Portal http://support.extremenetworks.com I get this fault :
"The server you are trying to access is either busy or experiencing difficulties. Please close the Web browser, open a new browser window, and try logging in again.[01:21:43]"
I'm using Google Chrome, if I use Internet Explore I will still get this message, but sometimes I will be able to log in and get to for example a .xos file download, but when I try to get it I will the get the same message.
Any body else have this problem ??
Photo of Tommy
Tommy
  • 342 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Robert Weiler
Robert Weiler
  • 92 Points 75 badge 2x thumb
Use an incognito window, that should help.
Photo of Drew C.
Drew C., Community Manager
  • 37,366 Points 20k badge 2x thumb
Hi Tommy,
As Robert mentioned above, you should be able to get in if you use an incognito window.  This is a problem that our web team is aware of and is working to fix.
You'll find some more information in this thread:  https://community.extremenetworks.com/extreme/topics/support-site-down
-Drew
Photo of Tommy
Tommy
Thanks for the replys
