Problem VRRP with VLAN.
  • 2
  • Problem
  • Updated 3 years ago
  • In Progress
Greetings.
I have two VRRP equipment S6, regarding VRRP configuration is as follows:
- Router 1:
set gvrp disable
set spantree stpmode none
interface vlan 1
vrrp create 1 v2-IPv4
vrrp address 1 10.18.4.250
vrrp priority 1 200
vrrp enable 1
interface vlan 2
vrrp address 1 10.18.5.254
vrrp priority 1 200
vrrp enable 1
interface vlan 10
vrrp address 1 10.18.10.254
vrrp priority 1 200
vrrp enable 1
interface vlan 31
vrrp address 1 10.18.31.254
vrrp priority 1 200
vrrp enable 1
- Router 2:
set gvrp disable
interface vlan 1
vrrp address 1 10.18.4.249
vrrp priority 1 50
vrrp enable 1
interface vlan 2
vrrp address 1 10.18.5.253
vrrp priority 1 50
vrrp enable 1
interface vlan 10
vrrp address 1 10.18.10.253
vrrp priority 1 50
vrrp enable 1
interface vlan 31
vrrp address 1 10.18.31.253
vrrp priority 1 50
vrrp enable 1
By doing tests on the operation of VRRP do the following:
Connect the links to the "switch A" and works well on VVRP. The problem is when I connect to a second switch "switch B and switch C" where the connection on my device VLAN 2 fails.
What I can do that would generate this problem ?.
Thank you very much!.
Photo of Luis Bernal
Luis Bernal
  • 120 Points 100 badge 2x thumb
Posted 3 years ago
  • 2
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
Could you change yo normal triangular topology with two core switches running vrrp
And one edge switch . Stp used for l2 loop prevention
What is the model number of core switches .
There are many solutions available
Ex mlag , EAPS
Luis Bernal
Good day.
There are two S6 chassis firmware 07.22.02.001, currently the core B is not connected to Internet (10.18.4.254) and have that problem.
The switches A, B and C are swicthes stack C5 series.
Thanks.
Photo of Christoph
Christoph
  • 1,812 Points 1k badge 2x thumb
You turned off STP on both routers. Regrading your picture you build a loop when adding a second or a third switch.
Kind regards
Christoph
Luis Bernal
Good day.
You say I activate STP?.
Thank you very much.
Photo of Christoph
Christoph
Like PARTHIBAN CHINNAYA said, you should think about re-designing you topology.E.g. put an additional direct connection between both routers and turn on stp. Or use VSB between the S-Series.
