Problem with C25 Controller WIFI
  • Question
  • Updated 3 years ago
  • Answered
Config Manager has suffered a critical error and will halt. Error Details: Failed to connect to database 'controllerConfig': Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (111)
Photo of bruno tortorella
bruno tortorella
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,670 Points 5k badge 2x thumb
Bruno
There isn't much information to go on here, you should consider opening a case with GTAC and provide a technical support file for analysis.
This article might also help: https://gtacknowledge.extremenetworks.com/articles/Solution/V2110-Can-t-connect-to-local-MySQL-server-through-socket-var-lib-mysql-mysql-sock
-Gareth
bruno tortorella
Thanks Mitchell,
i open a case for this issue.
Regards
Bruno T.
