problem with igmp snooping on summit 670 ?
  • Question
  • Updated 3 years ago
After few hours i see that multicast stops propagate. Disable igmp snooping [vlan] helps.
I suppose it's some bug in XOS, no info, errors in logs. My topology is only L2 with many vlans. It happens even within one switch. My xos v1531b4-patch1-18. Looking  for some info about known bugs, limits or info with soft is best to resolve this case.
big thanks for help
Photo of Pedro
  • 322 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
As per as I remember so many changes have been made and it seems might be hitting the bug where cache entry to not populating on multiple broadcom unit.
Below is the best solution:
If there are no routing protocols or VRRP configured on the ports where the protocol control packets are coming in we can configure IPMC to not periodically copy to the cpu:
                configure ipmc to-cpu off port <port-list>
