Problem with spaning tree on S Boning Switch Series
  • Question
  • Updated 1 year ago
  • Answered
Dear all, i have problems chaning my topology every minutes i think i have some trouble with spaning tree can someone help me how to find spaning tree port
Photo of Shkelqim Kajtazi
Shkelqim Kajtazi
  • 364 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
What model switch is this? and what version is it running? If it is an EXOS switch can you run "show stp <stp domain name>" and copy the output?
Photo of Daniel Coughlin
Daniel Coughlin, Employee
  • 2,648 Points 2k badge 2x thumb
Assuming you meant an S series switch I would start withe the following:
Support-> show spantree stats
Support-> show spantree blockedports
Support-> show spantree debug port *.*.* active
Support-> show port operstatuscause
(Edited)
Photo of Ash Curtis
Ash Curtis, Employee
  • 582 Points 500 badge 2x thumb
In EXOS, "show vlan" will help you to identify which ones have STP enabled on them - STP enabled vlans are denoted by the "T" flag.
You can then do "show vlan <vlan with STP enabled>" and it will show you which ports are being blocked by STP - blocked ports will have a "b" next to them.
"Show port <port> info detail" will then give you further information still about the state of the port and it's configuration.
(Edited)
Shkelqim Kajtazi
Core_SW(su)->show spantree stats
Spanning tree status         - enabled
Spanning tree instance       - 0
Designated Root MacAddr      - 02-00-0a-fe-63-0a
Designated Root Priority     - 0
Designated Root Cost         - 0
Designated Root Port         - 0
Root Max Age                 - 20 sec
Root Hello Time              - 2  sec
Root Forward Delay           - 15 sec
Bridge ID MAC Address        - 02-00-0a-fe-63-0a
Bridge ID Priority           - 0
Bridge Max Age               - 20 sec
Bridge Hello Time            - 2  sec
Bridge Forward Delay         - 15 sec
Topology Change Count        - 16946
Time Since Top Change        - 00 days 00:00:22
Max Hops                     - 20
Core_SW(su)->show spantree blockedports
Number of blocked ports in SID 0 : 0
Core_SW(su)->show spantree debug port *.*.* active
SID: 0, Bridge ID: 00-00-02-00-0a-fe-63-0a, Time Since TC: 00 days 00:00:46
Root Priority Vector
Root ID                      - 00-00-02-00-0a-fe-63-0a
External Cost                - 0
Regional Root ID             - 00-00-02-00-0a-fe-63-0a
Internal Cost                - 0
Designated Bridge ID         - 00-00-02-00-0a-fe-63-0a
Designated Port              - 0
Receive Port                 - 0         (none)
Alternate Ports          Designated Bridge
(none)
Ports with Received TC BPDUs         Count
--More-- <space> next page, <cr> one line, <q> quit
lag.0.4                                  112
lag.0.6                                  4
lag.0.8                                  2
lag.0.10                                 9326
lag.0.11                                 6
lag.0.13                                 54
lag.0.15                                 2
lag.0.19                                 6
lag.0.21                                 2
lag.0.22                                 2
lag.0.31                                 23078
lag.0.38                                 2
lag.0.46                                 6
ge.2.23                                  8
ge.2.24                                  354
ge.2.25                                  108
ge.2.27                                  6
ge.2.28                                  218
ge.2.32                                  176
ge.2.40                                  18
ge.2.42                                  7
Ports with Message Age Expired       Count
(none)
Ports with Exceptional Condition    Reason
(none)
STP Diagnostic Common Counters
Topology Change Count        - 16952
Message Expiration Count     - 0
Invalid BPDU Count           - 0
Disputed BPDU Count          - 32
STP BPDU Rx Count            - 0
STP BPDU Tx Count            - 0
STP TCN BPDU Rx Count        - 0
STP TCN BPDU Tx Count        - 0
STP TC BPDU Rx Count         - 0
STP TC BPDU Tx Count         - 0
RST BPDU Rx Count            - 33904
RST BPDU Tx Count            - 450979516
RST TC BPDU Rx Count         - 33490
RST TC BPDU Tx Count         - 1076938
MST BPDU Rx Count            - 8
MST BPDU Tx Count            - 0
MST CIST TC BPDU Rx Count    - 7
MST CIST TC BPDU Tx Count    - 0
SPT BPDU Rx Count            - 0
SPT BPDU Tx Count            - 0
SPT TC BPDU Rx Count         - 0
SPT TC BPDU Tx Count         - 0
STP Diagnostic Root History Table for SID 0
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Check lag.0.31 and the other lags that have high counters.  Do you have spangaurd turned on on the edge ports with adminedge?  What are your edge switches?
That looks like a good place to start.
Shkelqim Kajtazi
I use s800 series edge switch, yes the spaning tree is activated on rstp mode
here is my logging server
2017-06-12 18:10:51 Local0 Notice 10.10.7.11 Jun 12 18:10:49 10.10.7.11 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:51 Local0 Notice 10.10.7.45 Mar 17 03:40:22 10.10.7.45 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:51 Local0 Notice 10.10.7.22 Jun 12 18:10:49 10.10.7.22 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.61 Jun 21 21:00:20 10.10.7.61 NOTICE: Topology changed (Instance:0, Port:28,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.38 Jun 12 18:10:50 10.10.7.38 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.24 Jun 12 18:10:50 10.10.7.24 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.37 Jun 12 18:10:49 10.10.7.37 NOTICE: Topology changed (Instance:0, Port:24,MAC:20-B3-99-79-FA-E7) 2017-06-12 18:10:50 Local0 Notice 10.10.7.20 Jun 12 18:10:50 10.10.7.20 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.10 Jun 12 18:10:50 10.10.7.10 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.19 Jun 12 18:10:49 10.10.7.19 NOTICE: Topology changed (Instance:0, Port:24,MAC:20-B3-99-7A-15-9C) 2017-06-12 18:10:50 Local0 Notice 10.10.7.30 Jun 12 18:10:50 10.10.7.30 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.42 Jun 12 18:10:49 10.10.7.42 NOTICE: Topology changed (Instance:0, Port:27,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.29 Jun 12 18:10:49 10.10.7.29 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.17 Jun 12 18:10:49 10.10.7.17 NOTICE: Topology changed (Instance:0, Port:24,MAC:20-B3-99-7A-0B-E1) 2017-06-12 18:10:50 Local0 Notice 10.10.7.44 Jun 12 18:10:49 10.10.7.44 NOTICE: Topology changed (Instance:0, Port:27,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.21 Jun 12 18:10:50 10.10.7.21 NOTICE: Topology changed (Instance:0, Port:48,MAC:20-B3-99-7A-11-43) 2017-06-12 18:10:50 Local0 Notice 10.10.7.39 Jun 12 18:10:50 10.10.7.39 NOTICE: Topology changed (Instance:0, Port:24,MAC:20-B3-99-7A-0B-77) 2017-06-12 18:10:50 Local0 Notice 10.10.7.39 Jun 12 18:10:48 10.10.7.39 NOTICE: Topology changed (Instance:0, Port:24,MAC:20-B3-99-7A-0B-77) 2017-06-12 18:10:50 Local0 Notice 10.10.7.27 Jun 12 18:10:49 10.10.7.27 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.27 Jun 12 18:10:47 10.10.7.27 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.65 Jun 12 18:10:48 10.10.7.65 NOTICE: Topology changed (Instance:0, Port:28,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.33 Jun 12 18:10:50 10.10.7.33 NOTICE: Topology changed (Instance:0, Port:27,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.33 Jun 12 18:10:48 10.10.7.33 NOTICE: Topology changed (Instance:0, Port:27,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.23 Jun 12 18:10:49 10.10.7.23 NOTICE: Topology changed (Instance:0, Port:24,MAC:20-B3-99-7A-13-55) 2017-06-12 18:10:50 Local0 Notice 10.10.7.23 Jun 12 18:10:48 10.10.7.23 NOTICE: Topology changed (Instance:0, Port:24,MAC:20-B3-99-7A-13-55) 2017-06-12 18:10:50 Local0 Notice 10.10.7.13 Jun 12 18:10:49 10.10.7.13 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.13 Jun 12 18:10:47 10.10.7.13 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.15 Jun 12 18:10:50 10.10.7.15 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.15 Jun 12 18:10:48 10.10.7.15 NOTICE: Topology changed (Instance:0, Port:51,MAC:02-00-0A-FE-63-0A) 2017-06-12 18:10:50 Local0 Notice 10.10.7.12 Jun 12 18:10:47 10.10.7.12 NOTICE: Topology changed (Instance:0, Port:48,MAC:20-B3-99-75-2B-81) 2017-06-12 18:10:50 Local0 Notice 10.10.7.41 Jun 12 18:10:49 10.10.7.41 NOTICE: Topology changed (Instance:0, Port:24,MAC:20-B3-99-7A-0A-39) 2017-06-12 18:10:50 Local0 Notice 10.10.7.41 Jun 12 18:10:48 10.10.7.41 NOTICE: Topology changed (Instance:0, Port:24,MAC:20-B3-99-7A-0A-39)
every minutues my topology changes i dont know what heppen
(Edited)
Photo of Jeremy
Jeremy, Embassador
Hmm..
Run these commands on EDGE ports ONLY:
set spantree adminedge ge.1.1-48
Then
set spantree spangaurd enable
set linkflap globalstate enable
set linkflap action ge.1.1-48 gensyslogEntry
set linkflap portstate enable ge.1.1-48
Photo of Jeremy
Jeremy, Embassador
By edge ports, I mean on the 800 series.
Shkelqim Kajtazi
Yes but this commands is not working on my switch
Then
The cli on the 800 is a bit different
800-Series
enable stp
config stp version rstp
config stp ports 1-23 edge true (User port)
config stp ports 24 edge false (Uplink Port)
Photo of Jeremy
Jeremy, Embassador
Ahh, thanks for pointing that out!
no worries just trying to help.
Shkelqim Kajtazi
Thanks all for your reply, i have found the loop on edge switch, the command that i use is:
first to clear all stp stats
debug stp clear counter ports all
then to show stp stats
debug stp show counter ports all
and i got on port 23
TCN BPDU                  : 12554
thanks so much from all :D
Photo of Jeremy
Jeremy, Embassador
Glad you figured it out.
Glad you were able to get to the bottom of this.
