Problem with CPU and memory monitoring (MIBs)
  • Question
  • Updated 3 years ago
  • Answered
Hi everybody.
I have some troubles with CPU and memory monitoring on the Solarwinds monitoring system. I've gotten interface statistics, sysname, sysdescription, but I haven't found CPU and memory information.
Then I try to find ExtremeXOS MIBs, but unfortunately I haven't found it too.
Where can I find XOS MIBs? Can you give me advice about SNMP monitoring?
Photo of eyeV
eyeV
  • 2,484 Points 2k badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello EyeV the MIBS for XOS are on the esupport support site. If you can't login then call TAC at 18009982408.
P
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Few useful SNMP OID,
Name extremeCpuMonitorTotalUtilization
OID .1.3.6.1.4.1.1916.1.32.1.2
Name extremeCpuMonitorMaxUtilization
OID .1.3.6.1.4.1.1916.1.32.1.3.1.12
OID .1.3.6.1.4.1.1916.1.32.1.6.0
OID: .1.3.6.1.4.1.1916.1.32.3.0.1
OID: .1.3.6.1.4.1.1916.1.32.2.2
Name extremeMemoryMonitorSystemFree
OID: .1.3.6.1.4.1.1916.1.32.2.2.1.3
OID: .1.3.6.1.4.1.1916.1.32.2.2.1.4
OID: .1.3.6.1.4.1.1916.1.32.2.2.1.5
OID: .1.3.6.1.4.1.3375.1.1.78.0
OID: .1.3.6.1.4.1.3375.1.1.77.0
Photo of Josue Garcia
Josue Garcia
  • 60 Points
Hi Summit,
The values that you post are applicable for BD8810 ? could you provide details of how to achieve the following:
Need the oid values for BD8810 to monitor on Cacti: Current CPU Utilization per MSM, Memory Utilization (System, User, Free) per MSM, System Storage (Used and Free), and per VLAN L3 Utilization.
However, If is necessary I can open a case.
Photo of eyeV
eyeV
Thank you Paul and thank you Sumit. I use SNMP-walk and I don't find any 1.3.6.1.4.1.1916.1.32.1 or 1.3.6.1.4.1.1916.1.32.3 OIDs. My list begins from .1.3.6.1.4.1.1916.1.32.2.2.1.3.1.
Should I change something on the switch or my configuration is enough.
configure snmp sysName "xxx"
configure snmp sysLocation "xxx"
configure snmp sysContact "xxx"
# Module snmpMaster configuration.
configure snmpv3 add community $MyRWCommunity$ name $MyName$ user v1v2c_rw
configure snmpv3 add community $MyROCommunity$ name $MyName$ user v1v2c_ro
configure snmpv3 add target-addr v1v2cNotifyTAddr1 param v1v2cNotifyParam1 ipaddress 172.30.0.6 transport-port 162 tag-list defaultNotify
configure snmpv3 add target-params v1v2cNotifyParam1 user v1v2cNotifyUser1 mp-model snmpv2c sec-model snmpv2c sec-level noauth
disable snmpv3 default-group
disable snmpv3 default-user
configure snmp access-profile mgmt-acl readwrite
entry ManagementACL {
        if match any {
                source-address 172.30.0.0/16;
                source-address 172.20.0.0/16;
                source-address 192.168.0.0/23;
        } then {
                permit;
P.S. Thank you so much. You really help me.
(Edited)
Photo of eyeV
eyeV
Sorry, I've found it.
Sumit Tokle, Alum
Can you let us know what information you found?
Photo of eyeV
eyeV
I've found OIDs in my snmpwalk list. Anyway OID .1.3.6.1.4.1.1916.1.32.1.6.0 doesn't work, but other OIDs from your list works perfectly.
Photo of Davor
Davor
  • 162 Points 100 badge 2x thumb
We have issue with pooling system info (cpu, mem etc.) from X8 with Solarwinds. I also tryed to pull with Paessler and some other snmp tools. some of those OIDS are correct but some do not show usable info.
I have also troubles importing Extreme Networks MIB file to lot of SNMP tools. What is deal with that. What MIB/OID tool you use that can import Extremes MIB file correctly?
What OID's to use on X8?
(Edited)
Photo of Ted
Ted
  • 1,174 Points 1k badge 2x thumb
Is there a config or concept guide on this one.  I have summit switches and 8810's that need I want more viability using Solarwinds.
Photo of Drew C.
Drew C., Community Manager
  • 37,334 Points 20k badge 2x thumb
I'm not very familiar with the ins and outs of Solarwinds... Can you import the EXOS MIB into the program to help make configuration easier?
Photo of Ted
Ted
I believe so.  They have a basic set but always seems like something is missing.
Is there a config guide or document for all the Extreme snmp OID's?
Photo of Drew C.
The MIB file is somewhat tied to each EXOS version.  If you have access to esupport/extranet, you should be able to download it for your particular version.  If you can't find it, let me know what version your EXOS gear is running and I can get it to you.
Once it's imported, you should be able to browse and search for specific areas of interest.
I'm not aware of a specific SNMP guide, though one may exist - sorry.
Photo of Ted
Ted
Ok Thank you.
