Problem with rate-limit on summit X650
  • Question
  • Updated 4 years ago
Create Date: Apr 11 2012 3:50AM
Hello,
I have two X650 stacked together they both have firmware XOS 12.5.4.5 v1254b5-patch1-6.
I set rate-limit flood broadcast for example 1000pps on 10G port 1:15 and I see on show ports rate-limit flood command that Flood Rate Exceeded is still increasing. The problem is that on graphs I see only 300pps of broadcast traffic the same thing is when i do show port statistics command, values of broadcast traffic are increasing about ~300pps. So I did a test and configured rate-limit flood broadcast for this port to 200000pps .. and i show ports rate-limit flood Flood Rate Exceeded is still increasing.
Maybe somebody could test it on their switches or explain to me what I'm doing wrong.
best regards,
Lukasz Biedka
(from Lukasz_Biedka)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Apr 11 2012 10:49AM
How about unconfiguring the meter and see the pps in show port stats? Do you genuinely have a large number of broadcast packets coming in?
This could also be a bug with the counters. Verify with TAC
Let us know what the outcome is.
(from Arpit_Bhatt)
