Problems with DHCP Relay on VLANs
  • Problem
  • Updated 2 months ago
  • Not a Problem
  • (Edited)
Hi Champs,
I have a RFS6000 with wing 5.8.3.1 firmware and i'm trying to enable the DHCP RELAY on one of my vlans. But, when a check the box ''Respond to DHCP Relay Packets" and point the IP address on DHCP relay list, i get this error message:
Detail :Not Available
Message :Both, dhcp-relay-incoming and ip-helper-address, are configured on interface vlan1
ErrorPath :/wing-config/device[mac='B4-C7-99-6E-D4-30']
Severity :error
Type :Application Error
why DHCP relay and IP-helper are conflicting? Some configuration are incorrect?
Photo of Matheus Santana
Matheus Santana
  • 102 Points 100 badge 2x thumb
Posted 2 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 46,998 Points 20k badge 2x thumb
You need a helper to forward a broadcast DHCP request to a unicast into another subnet/VLAN.
No need for a helper in the same subnet/VLAN.
As per the error you try to configure a helper that rx/tx on the same subnet/VLAN.
