Problems related to port utilization command
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Jul 12 2012 9:29AM
Hi ExpertWe are facing the following problem: we are making graphics with the port utilization, but after an upgrade from EW 7.6.2.1 to 7.8.4.1 patch1-r4 the graphics on switch B (we have vrrp master - slave) the traffic curve is flat, like if the switch would be making rate shaping or something like that. The thing is, after perform a "show tech-support all" the graphics shows an increment on the traffic and the curve now is "normal" .Can somebody to explain how works "show tech-support" ? Why could be affecting in some way the reporting on show port utilization?Thanks in advance!Roxana
(from Roxana_Rojas)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jul 20 2012 8:03AM
You could use SNMP to create graphs for the utilization.
(from Rickard_Sellstedt)
