Problems with comparing a string with a variable
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Jul 11 2013 2:15PM
I want to compare the content of a variable with a string, but it doesn't works.
Here the posting of some examples and the error messages which I get:
# variables
set var count 0
set var par1  "Image"
# example 1
set var count ($count + 1)
show var count
while ("$par1" != "Image") DO
show var $par1
endwhile
# Message:
# Error:can't read "par1": no such variable
# Variable Image not found.
# Error: Mismatched ENDWHILE
# example 2
show var count
while ("Image" != "Image") DO
show var $par1
endwhile
# No Error-Message
# example 3
show var count
while (part1 != "Image") DO
show var $par1
endwhile
#Error-Message:
#Error:syntax error in expression "(part1 != "Image")"
#Variable Image not found.
#Error: Mismatched ENDWHILE
Does somebody knows the rigth syntax?
(from Hans_Vedder)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jul 11 2013 4:31PM
try -> while ( $par1 != "Image")
Jarek
(from Jaroslaw_Kasjaniuk)
Create Date: Jul 12 2013 8:21AM
I tried:
while ($par1 != "Image") DO
show var $par1
endwhile
and get the error message:
Error:syntax error in expression "(Image != "Image")"
(from Hans_Vedder)
Create Date: Jul 12 2013 2:32PM
Ah..that was strings ..
maybe this would help you
while ( ! [string equal $par1 "Image" ] ) do
Jarek
Create Date: Jul 15 2013 12:12PM
Thank you very much. This works fine.
You used the syntax:
while ( [string equal $par1 Image ] ) do
Where do I find the syntax of the string command? It's not described in the Concepts Guide 15.3.
There I read:
== Boolean equal
!= Boolean not equal
Each operator produces a zero or one result. These operators are valid for all operand types.
(from Hans_Vedder)
Create Date: Jul 15 2013 12:30PM
That is TCL language, in EXOS you can use it but it's a bit "limited version".
You can find many examples in the internet, for exampl. http://wiki.tcl.tk/.
Jarek
