Prompt for input / edit script?
  • Question
  • Updated 4 years ago
  • Answered
Create Date: Aug 23 2012 8:29AM
I am writing a 'default' config script, basically to apply all of our default settings for a switch.
What i would like to do, but can do without, is to prompt the users for a number and assign that number as the IP of the switch.
command equiv:
configure vlan VLAN-Default ipa 192.168.1.X
I know i can make a variable and think i could apply the variable to the command, however i am not sure if it is possible to interupt a script to ask for input / resume script.
I want to know if during a script i can prompt the user to enter a number and apply that number to X / then execute that command and move on.
Alternatively I can tell users to just edit the script each time and change the IP to whatever it needs to be (not use a variable).  I want to IP the switch as part of the general config so that i can also add default route, dns, etc (at least the default route won't enter until the vlan is IP'd).
Thanks
(from Nick_Lindhag)
Photo of EtherNation User
EtherNation User, Official Rep
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Aug 23 2012 9:45AM
For prompting of variables at the command line.
set var myVar $READ(Description.)
Hope this helps
(from john_padilla)
Create Date: Aug 26 2012 6:25PM
OR, if you need only one (or two) variables - you can pass them to the script as parameters (using $CLI.ARGV1 ..."load script myScript variable1 variable2")
For more variables, the GUI version is the best one; $READ works anytime so it will be your call in the end.
(from Eugen_NAIMAN)
