protocol based VLAN not working
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Configuration done to perform packet filter based on "Protocol Based VLAN", traffic was captured via mirroring and I see packets are not forwarding to correct VLAN.
Configuration for port 7:
Summit48si:18 # show port 7 vlan info
Name               VID  Protocol Addr           Flags        Proto   Ports
Payload            333  10.10.20.130  /25   ------f------- mnet   11/20
OM_Node         332  10.10.20.50   /28   v-----f------- ANY    10/20
OM_RPP          192  192.168.0.2    /24 ------f------- mnet   11/20
Internal              46                                ------------------ --------       p1      7/36
Mirror Results:
1) Using "enable mirror add port 7 vlan "Payload" I just see traffic to network 10.10.20.128/25. There is no traffic from network 10.10.20.128/25
2) Using "enable mirror add port 7 vlan OM_Node" I am able to see traffic from  network 10.10.20.128/25, but traffic is been received by different VLAN than expected which proves mnet protocol based is not working for some reason!
Additional Information:
- It happens for swiches Summit 48si running EOS "7.8.4.1 patch1-r4" & EOS "7.8.4.1".
- "enable multinet" is configured
- "create protocol mnet" is configured
Someone can help me uinderstand what is wrong?
Thanks in advance,
Wanderley Benacchio Junior
Photo of Wanderley Benacchio
Wanderley Benacchio
  • 150 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Hi Wanderley,
Is the port receiving/sending that traffic configured as "tagged" to the protocol-based vlan?
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,594 Points 10k badge 2x thumb
What does the configuration for the 'mnet' protocol filter look like?
Wanderley Benacchio
Hi Henrique,
Port 7 is added to all VLANs as untag. That is why we need "protocol based" to coorectly decide to which VLAN packet shall be addimited.
Photo of Henrique
Henrique, Employee
Hi Wanderley, thanks for your confirmation. Just to confirm since tagged has more priority than protocol-based.
It seems to be related to the protocol filter configuration.
Wanderley Benacchio
I would say thanks for your time & help ;-)
As I have commented with Brandon, I suppose "mnet" is a predefined protocol where is performed a comparation of Packet Source IP Address against VLAN network and in case it matches packet will be addmited on that VLAN, but I do not see so much references to "mnet".
Do you have docs that explain how "mnet" works?
When I do a "mnet" printout I see this:
SW# show protocol mnet
  Protocol Name     Type  Value
mnet
SW#
Wanderley Benacchio
Hi Brandon,
I suppose mnet is a predefined protocol where is performed a comparation of Packet Source IP Address against VLAN network and in case it matches packet will be addmited on that VLAN. Anyway see printout for mnet protocol:
mnet
SW#
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,792 Points 10k badge 2x thumb
Hi Wanderley,
as far as I understand it, you need to configure the manually created protocol with name mnet:
configure protocol mnet PARAMETERS
The parameters describe the layer 2 (Ethernet) values that define this protocol.
I am quite sure that this mechanism does not consider IP addresses.
Br,
Erik
Erik is correct, 'mnet' is a protocol filter that you created, and it must be manually defined as to what traffic goes into it.
Hi Brandon,
there seem to be examples using an "mnet" protocol filter as a dummy in the ExtremeWare 7.8 User Guide regarding Multinetting. But I have never used this feature and I do not know why this dummy protocol is needed.
I would suggest Wanderley to take a look at the examples there and try to follow them as close as possible.
Erik
Hi Wanderley,
your questions seems to be related the IP Multinetting Operation section starting on page 670 of the ExtremeWare 7.8 User Guide. There a dummy protocol mnet is created w/o protocol parameters.
In the examples there, one of the VLANs is configured to use protocol ip, all others to use mnet.
Br,
Erik
Photo of Henrique
Henrique, Employee
Based on the User Guide example, it seems that changing your vlan "OM_Node" protocol filter from "ANY" to "ip" should work.
There are 2 important comments:
  • All VLANs used in the multinetting application must share the same port assignment.
  • One VLAN is configured to use an IP protocol filter. This is considered the “primary” VLAN interface for the multinetted group.
as I understand it, IP Multinetting (enable multinet) is used as a proprietary substitute for secondary IP addresses which were not supported until ExtremeWare 7.3:
IP multinetting is used in many legacy IP networks when there is need to overlap multiple subnets onto the same physical segment. Though it can be a critical element in a transition strategy, due to the additional constraints introduced in troubleshooting and bandwidth, it is recommended that multinetting be used as a transitional tactic, and not as a long-term network design strategy.
I do not see any provision to separate the traffic into different VLANs. On the contrary, this multinetting seems to join the different VLANs together.
Please note that I have not used or tried out the multinetting feature, I just try to understand it based on the documentation.
Br,
Erik
