PTP Transparent clock : What switches are capable of doing so?
  • Question
  • Updated 1 year ago
  • Answered
When using transparent clocking : what switches are be able to adapt the ethernet frame going through them ?
Photo of Pascal Lurquin
Pascal Lurquin
  • 970 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,304 Points 10k badge 2x thumb
Hi Pascal,
PTP is supported on the Summit E4G-200, E4G-400, X770, X670-G2, and X460-G2. Note that if you are using the E4G-200 or X460-G2, there is a clock module that is required to be installed in the switch as well.
Photo of Bin
Bin, Employee
  • 5,370 Points 5k badge 2x thumb
Hello Pascal,
Add the reference of PTP on EXOS switch.
http://documentation.extremenetworks.com/exos/EXOS_21_1/Slots_and_Ports/c_using-the-precision-time-p...
Regards,
Bin
Pascal Lurquin
Thanks!
If we are using the Summit 870 in the network: can we use it with only PTP transparent clocking ?
  • 13,280 Points 10k badge 2x thumb
The X870 does not currently support PTP.
(Edited)
