Purview Dual Interface Mirrored not showing application and network response time
  • Problem
  • Updated 1 year ago
  • Not a Problem
In trying to set up Purview, I am getting the flows in netsight.  It is not showing response times for network or applications.  It could be a configuration issue as this is my first time really diving into Purview.
I have it configured in Dual Interface Mirrored.  I am seeing traffic on eth0 and eth1.
Below is my configuration:
# mirror
set mirror create 1
set mirror 1 mirrorN 15
set mirror ports ge.1.1 1
# netflow
set netflow export-interval 1
set netflow export-destination 192.168.10.53 2055
set netflow export-version 9
set netflow port ge.1.36 enable rx
set netflow template refresh-rate 30 timeout 1
set netflow cache enable
Jumbo frames, port duplex, and port speed have all been set.
I have one port going from one of my cisco switches in the network to an SSA. I have the span set for both at the moment on the one port.  I have also tried 2 ports between with rx on one and tx on the other.  Still have the same result.
Photo of Jeremy Evans
Jeremy Evans
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Jeremy Evans
I failed to mention that this is a virtual appliance on vmware.  Promiscuous mode and jumbo frames are enabled on here also.
