Purview Flow CSV Export
Andre_Brits_Kan
Contributor II
Hi
If we look at the Application Flows in "Purview" we see all the current flows.
You have the option of exporting this to a CSV file.
I would like to export all the flows for a specific client for the last week.
Can this be done?
Thx
1 REPLY 1
Frank_Thomas
No,
Unfortunately no, you can export aggregate flows up until the limit [Based on number of flow/memory allocation]. Bottom of the application flow grid.
5c5e7bf922f94482b1901065f83ae04d_RackMultipart20160711-88690-gv6uln-AggregateFlowTime_inline.png
Purview isn't really designed for data retention for raw flow data, generally we would recommend you export it to SIEM.
