python process termination
  • Question
  • Updated 2 years ago
  • Answered
I have a question on what happens when a process is terminated.
I create a process:  create process Proc python-module [python file] start on-demand
I then start it: start process Proc slot 1
When I terminate it: terminate process Proc gracefully slot 1
Is there an exception that I can catch in my python script so I can do some kind of cleanup or extra logging before the process completely dies?
Photo of bw447
bw447
  • 966 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Dave Hammers
Dave Hammers, Dir SW Engineering
  • 3,722 Points 3k badge 2x thumb
Unfortunately, no.
The 'create process' in EXOS runs the python code in its own thread which means python threading rules apply.
A possible future enhancement would be to signal the thread in some fashion that a SystemExit exception occurred, but that doesn't help you in currently shipping EXOS.
Photo of bw447
bw447
@Dave, Thanks for the explanation!
Photo of bw447
bw447
@Dave,  Currently we are running 16.1.3.6
I prefer to get the output from a command as xml when running a script:
exsh.clicmd(cmd, xml=True)
Are there plans to be able to get xml output from a process?  From what I see in the Python doc it's only possible to receive output as regular text.
Thanks!
There is a way to do this but it's a bit involved. We do something similar to return JSON from CLI commands.when writing EXOS python apps.
Create a script cli2xml.py with the following 3 lines:
import sys
cmd = ' '.join(sys.argv[1:])
print exsh.clicmd(cmd, xml=True)
You can test this by the CLI command: run script cli2xml.py show port 1 no-refresh
It's also handy when you want to see what the XML output of a command looks like before writing any code.
In your python application, invoke the EXOS command shell to run cli2xml.py with your command.
Below is an example:
# This is an example of a class that would interface to cli2xml.py in the Python application
# environment
import subprocess
class ExosCliToXml(object):
    def __init__(self):
        self.dummy = None
    @staticmethod
    def exos_cli2xml(cmd):
        shell_cmd = "/exos/bin/exsh -n 0 -b -c 'run script cli2xml.py {0}'".format(cmd)
        p = subprocess.Popen([shell_cmd], shell=True,
                stdin=subprocess.PIPE,
                stdout=subprocess.PIPE,
                stderr=subprocess.PIPE)
        (stdoutdata, stderrdata) = p.communicate()
        return (stdoutdata, stderrdata)
# test stub
cli = ExosCliToXml()
while True:
    cmd = raw_input('enter command > ')
    if cmd in ['quit', 'exit']:
        break
    (stdoutdata, stderrdata) = cli.exos_cli2xml(cmd) # print the XML output from the command
    print stdoutdata
If you wanted to use JSON, there is already a script shipping with EXOS: cli2json.py
E.g. run script cli2json.py show port 1
In the class, change cli2xml.py to cli2json.py for JSON output.to change from XML to JSON
(Edited)
Photo of bw447
bw447
Hello Dave,
Thanks for the info. Below I'm getting the following Permission denied when I run your test script up above.  I'm seeing the Permission denied output because I added 'print stderrdata' after your last print stdoutdata statement up above.
* Slot-1 Kenn-B.8 # run script CliToXml.py
enter command > show version
/bin/sh: /exos/bin/exsh: Permission denied
enter command > quit
I tried it with the JSON output by changing the script name as you said at then end of your comment and I received the same Persmission denied error.
I'm running this script as the local admin account.
Any thoughts?
Sorry, I wasn't clear. This has to be run from the EXOS process environment i.e. from the python that you give to 'create process'.
My test stub was a bad example since I bypassed the restrictions to validate the class.
If you include the class in your applications and call cli.exos_cli2xml(cmd) within the application, it should work for you.
The parts that are available from the normal CLI are:
run script cli2xml.py <cmd> < - this would be your new 3 line script
run script cli2json.py <cmd> <-this is the script already shipping with EXOS
(run script cli2json.py -d <cmd> creates a more human readable output)
Photo of bw447
bw447
Got it!  Thank you sir!
