Python script triggered by UPM doesn't work properly
  • Problem
  • Updated 3 years ago
  • Solved
  • (Edited)
Hi everybody.
I use x480 with 16.1.2.
I have simple .py script like this.
import pexpect
import exsh
exsh.clicmd ('create log message "Starting NSCBackup!"')
for i in range(1,10):
print(i)
p = pexpect.spawn('/exos/bin/ssh -r 2 USERNAME@172.20.1.' + str(i))
idx = p.expect(['password', pexpect.EOF, pexpect.TIMEOUT])
p.sendline('SECRETPASS')
idx = p.expect(['sCore', pexpect.EOF, pexpect.TIMEOUT])
p.sendline('create log message "Not so cold backuper"')
p.sendline('save')
idx = p.expect(['(y/N)', pexpect.EOF, pexpect.TIMEOUT])
p.sendline('y')
p.sendline('scp2 vr "VR-Default" sCore' + str(i) + '.cfg USERNAME@172.20.1.10:sCore' + str(i) + '.cfg')
p.sendline('exit')
Not so beautiful, but it works!
So... I can run it with "load script NSCB.py". It works properly.
Then I created and scheduled UPM profile like this.
create upm profile NSCB
load script NSCB.py
create upm timer NSCBtimer
configure upm timer NSCBtimer profile NSCB
configure upm timer NSCBtimer at 11 5 2015 23 50 0 every 86400
And I run it:
run upm profile "NSCB"
I see some log messages, but script stucked.
11/06/2015 15:55:19.94 <Info:System.userComment> Starting NSCBackup!
11/06/2015 15:55:19.54 <Noti:UPM.Msg.upmMsgExshLaunch> Launched profile NSCB for the event user-request
Any suggestions?
Photo of eyeV
eyeV
  • 2,484 Points 2k badge 2x thumb
Posted 3 years ago
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
You do a print, but in upm I dont know what happens to that print, does it work if you remove that print(i) ?
Photo of eyeV
eyeV
Unfortunately no.
Photo of OscarK
OscarK, ESE
ok, I think you should add some checks where you send some info to the log to keep track where it is stuck.
Photo of eyeV
eyeV
Yeah, I'm doing it right now. )
Photo of eyeV
eyeV
It stucked right after for loop begins.
Photo of OscarK
OscarK, ESE
Maybe it is a rights thing and is ssh not executable by a script launched by UPM.
Photo of Matthew Helm
Matthew Helm, Employee
  • 200 Points 100 badge 2x thumb
So it looks like the purpose of this is to have a core switch ssh into downstream connected switches and save their configurations periodically right?
I'll take your script and attempt to make it into a python EXOS application process instead. I'll then test having a UPM process restart the py process. I'll let you know how it works out.
Let me know if I've misinterpreted what you want to do.
Thanks.
Photo of eyeV
eyeV
Yes, the concept is right.
I was able to create a test.py application/process that uses pexpect with /exos/bin/ssh similarly to your script and I used a UPM profile and timer to restart it every 5 minutes. It worked.
Here is the UPM configuration:
## Module upm configuration.
create upm profile test
disable cli prompt
restart process test
create upm timer test
configure upm timer test profile test
configure upm timer test after 1 every 300
And here is the py file for the process and the command to create it. (I assumed that the ssh targets were sub-tended EXOS switches and so I sent the "disable cli prompting" command to avoid unnecessary pexpect lines in the process script.)
#vi test.py
import pexpectimport exos.api
def exosCmd(cmd):
   reply = exos.api.exec_cli([str(cmd)], ignore_errors=True)
   return str(reply)
def logMsg(m):
    exosCmd('create log message "{0}"'.format(m))
logMsg("Starting NSCBackup!")
p = pexpect.spawn('/exos/bin/ssh -r 2 admin@10.0.0.202')
p.sendline('admin')
idx = p.expect(['x202', pexpect.EOF, pexpect.TIMEOUT])
p.sendline('create log message "test test test"')
p.sendline('disable cli prompt')
p.sendline('save')
p.sendline('exit')
#^wq!
The process was started with this line that I issued before starting the UPM timer:
create process test py test start auto
Hope this helps.
Photo of eyeV
eyeV
Thank you for advice! I'm going to create similar proccess and give you feedback as soon as possible.
Photo of eyeV
eyeV
Sorry for waiting... Something is going wrong.
I've created py script, but when I run it I have this.
Traceback (most recent call last):
  File "/config/NSCB.py", line 2, in <module>
    import exos.api
  File "/exos/tools/lib/python2.7/site-packages/exos/api/__init__.py", line 21, in <module>
  File "/exos/tools/lib/python2.7/site-packages/exos/api/ems.py", line 10, in <module>
ImportError: No module named _exos_ext_ems
I've tried to import XOS api with "from exos import api" but...
from xos import api
ImportError: No module named xos
It's not clear for me... What am I doing wrong?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,672 Points 10k badge 2x thumb
You need to run EXOS 15.7 minimum in order to create Python App (process). Are you running 15.6 ?
Photo of eyeV
eyeV
I'm running 16.1.2.14.
oh, I misread, sorry.
Try that :
instead of
from xos import api
(Edited)
Photo of eyeV
eyeV
Same result...
What XOS version do you run?
(Edited)
Photo of eyeV
eyeV
It's not the version problem. I've tried 16.1.1.4, same result. The script doesn't run with upm profile.
run script NSCB-old.py
11/17/2015 11:26:53.88 <Info:System.userComment> Starting NSCBackup!
11/17/2015 11:26:53.44 <Noti:UPM.Msg.upmMsgExshLaunch> Launched profile NSCB for the event user-request
I can't even execute single-line script "from exos import api". You can see traceback in previous post.
(Edited)
Photo of eyeV
eyeV
Yeah! I've fixed it! Thanks everybody!
Photo of Drew C.
Drew C., Community Manager
  • 40,206 Points 20k badge 2x thumb
What was the problem? :)
Photo of eyeV
eyeV
It was interesting. I've learned that there are two python environments in EXOS actually. This thread. So I can't execute "import exos.api" just by typing "run script blalbalba.py", but I can do it when I create process with this .py script. It's a bit confusing.
Moreover the "from exos import api" string doesn't work at all.
Sorry for my poor English )
  • 13,546 Points 10k badge 2x thumb
Did you read the Python Getting Started Guide?
http://www.extremenetworks.com/wp-content/uploads/2015/02/Python_Getting_Started_Guide.pdf
It might help you.
Photo of eyeV
eyeV
Yes, I read it. Very useful document actually, but, as I say above, "from exos import api" line from this guide doesn't work for me. I guess I just don't fully understand something.
(Edited)
